Born to drive a Porsche
knod socket problem (dashboard)
This is my problem,
I have the 2 knobs in the dash ( defrost & fog lights) and every time I want to use it , the knob stay in my hand ( when pulled) I have remove everything to see if some parts could be damaged but , nothing. It looks like the end of the knob is to short and cannot reach the socket. What do you think and do I have to change the socket?? Help me please ![]() ![]() ![]()
Rennsport / PCA Region Porsche 911 Carrera 3.2 1984 Ford Edge SEL 2012 Volvo S60 AWD 2.5 turbo 2006(SOLD) Jeep Wrangler Off road 2002 (SOLD) ![]() |
Nobody as an idea where I can find this part?
I went thru all pelican parts and cannot find it... ![]()
pelican sells them. I had the same problem and they only list the defrost switch which is the same as the 2 stage fog switch on euro cars. The new switch comes without the knob so yours will be used.
911-613-147-00-OEM I see that you're in Montreal, try giving a call to nineapart for used switches, they are sometimes just as expensive as new parts though... Or check with the dealer. later David
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
So when you screw the plastic collar down all the way onto the part int he dash- the actual switch-, you still can't screw the knob in far enough to get it to hold?
Thanks guy's
Yes , this is my problem Group911. No grip at all and the knob look's intact I have to change both ( defrost and fog lights) . Thanks Roby 466 for the part number. I will compare with nineaparts too.
I bought used switched from these guys. They were reasonably priced and worked great.
Weekend Rides LLC - One of the largest used Porsche 911 parts and rebuildable Porsche salvage companies in the world. |
RETIRED
Sounds like the internal threads are stripped.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
