Born to drive a Porsche
dany911's Avatar
knod socket problem (dashboard)
This is my problem,
I have the 2 knobs in the dash ( defrost & fog lights) and every time I want to use it , the knob stay in my hand ( when pulled) I have remove everything to see if some parts could be damaged but , nothing. It looks like the end of the knob is to short and cannot reach the socket.
What do you think and do I have to change the socket??
Help me please
Rennsport / PCA Region
Porsche 911 Carrera 3.2 1984
Ford Edge SEL 2012
Volvo S60 AWD 2.5 turbo 2006(SOLD)
Jeep Wrangler Off road 2002 (SOLD)
Old 12-29-2010, 05:11 PM
dany911's Avatar
Nobody as an idea where I can find this part?
I went thru all pelican parts and cannot find it...
Ford Edge SEL 2012
Old 12-30-2010, 07:37 AM
Roby466's Avatar
pelican sells them. I had the same problem and they only list the defrost switch which is the same as the 2 stage fog switch on euro cars. The new switch comes without the knob so yours will be used.
911-613-147-00-OEM
I see that you're in Montreal, try giving a call to nineapart for used switches, they are sometimes just as expensive as new parts though...
Or check with the dealer.
later
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 12-30-2010, 07:46 AM
group911@aol.co's Avatar
So when you screw the plastic collar down all the way onto the part int he dash- the actual switch-, you still can't screw the knob in far enough to get it to hold?
Thanks,
Bob
group911@aol.com
Old 12-30-2010, 07:48 AM
dany911's Avatar
Thanks guy's
Yes , this is my problem Group911. No grip at all and the knob look's intact
I have to change both ( defrost and fog lights) . Thanks Roby 466 for the part number. I will compare with nineaparts too.
Ford Edge SEL 2012
Old 12-30-2010, 07:57 AM
I bought used switched from these guys. They were reasonably priced and worked great.
Weekend Rides LLC - One of the largest used Porsche 911 parts and rebuildable Porsche salvage companies in the world.
Old 12-30-2010, 08:24 AM
RETIRED
Joe Bob's Avatar
Sounds like the internal threads are stripped.
2012 ML350 3.0 Turbo Diesel
Old 12-30-2010, 08:46 AM
