2.7 911 S engine
Hello,
Can anyone tell me if this is the correct fan pulley for my 1974 911S? The fan belt is extremely loose and I need to know if it is because of the pulley being incorrect? how do you like the make shift coil wire? I got this thing from some hacker!!!!! Thanks for any help guys. I am going to need a lot more as I keep finding things. ![]() ![]() |
That looks to be the correct pulley. How many shims are between the pulley halves? Have you tried to adjust the tension? You should have a total of six shims to move around between the pulley halves and the outside pulley nut to adjust the tension.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Thanks for your time. |
Banned but not out, yet..
Me thinks you need shims. If you got a too kit with the car, the pulley tool hopefully is in it - kind of like a two tongued fork. And I agree the pulley looks correct.
An air cooled refrigerator. ‘Mein Teil’ |
Band.
I think I see a few shims on there right now. Make sure you have the right size belt, too!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Agree with Gogar, I think I see some shims behind the nut washer, however for a loose belt you will need to remove the shims from between the pulley halves.
Two possible belts, both offered by our host. 10 X 710 by Contitech and 9.5 X 710 by Porsche
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 01-04-2011 at 07:51 AM.. |
You will need this type fan pulley wrench.
thanks for the info. Hopefully moving down the road soon. You should see the ignition system wires, plugs, cap and rotor. Just hideous! in great need of a valve adjustment. Timing was so far advanced it is amazing the car was running. Has me asking, "what have I gotten myself into"?
Thanks again i will pick two up. should I use bosch plugs or NGK? It has a Permatune CDI box in it and I am replacing the coil with a new bosch unit.
