2.7 911 S engine
Hello,
Can anyone tell me if this is the correct fan pulley for my 1974 911S? The fan belt is extremely loose and I need to know if it is because of the pulley being incorrect? how do you like the make shift coil wire? I got this thing from some hacker!!!!! Thanks for any help guys. I am going to need a lot more as I keep finding things.
Old 01-03-2011, 05:12 PM
That looks to be the correct pulley. How many shims are between the pulley halves? Have you tried to adjust the tension? You should have a total of six shims to move around between the pulley halves and the outside pulley nut to adjust the tension.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-03-2011, 05:37 PM
To tell you the truth I doubt if there are any shims in the proper location on the pulley. But it is good to know the pulley is correct. Do you know the pulley wrench I need? I have one for my 77 911 but I don't see any holes on this pulley for that tool. Sorry if this is remedial but we all have to start some where.
Thanks for your time.
Old 01-03-2011, 05:56 PM
Banned but not out, yet..
RSBob's Avatar
Me thinks you need shims. If you got a too kit with the car, the pulley tool hopefully is in it - kind of like a two tongued fork. And I agree the pulley looks correct.
Old 01-03-2011, 08:17 PM
Band.
I think I see a few shims on there right now. Make sure you have the right size belt, too!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-03-2011, 08:27 PM
what is the correct size belt? Just need to make sure. Thanks
Old 01-03-2011, 09:49 PM
Agree with Gogar, I think I see some shims behind the nut washer, however for a loose belt you will need to remove the shims from between the pulley halves.
Two possible belts, both offered by our host. 10 X 710 by Contitech and 9.5 X 710 by Porsche
L.J.
Old 01-04-2011, 07:45 AM
You will need this type fan pulley wrench.
L.J.
Old 01-04-2011, 07:48 AM
thanks for the info. Hopefully moving down the road soon. You should see the ignition system wires, plugs, cap and rotor. Just hideous! in great need of a valve adjustment. Timing was so far advanced it is amazing the car was running. Has me asking, "what have I gotten myself into"?
Old 01-04-2011, 03:55 PM
Thanks again i will pick two up. should I use bosch plugs or NGK? It has a Permatune CDI box in it and I am replacing the coil with a new bosch unit.
Old 01-04-2011, 03:57 PM
