problem removing front bumper...
tried taking the 4 bolts off holding the front bumper on but they just turn, and turn, and turn, and turn, with no change... any suggestions or help?
Old 01-13-2011, 01:34 PM
Should just be 4 nuts behind the rubber strip on the bumper (on a 74-89 911). Maybe a previous owner modified your bumper? Oh, and you also have to detach the accordion pieces...just the two small nuts that attach near the wheel well.
Old 01-13-2011, 01:39 PM
Recreational User
porschenut's Avatar
They're definitely nuts, attached to 4 threaded studs that protrude from the front of the bumper shocks. If you're working on bolts, something's wrong there....
Old 01-13-2011, 02:33 PM
Less brakes, more gas!
euro911sc's Avatar
your studs may have come unwelded? Hard to imagine, but possible I guess. After removing the accordions you may be able to get at the shocks and undo those to pull the bumper off. Each bracket has 2 bolts and the one at the end of the shock to get them out.
Good luck!
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 01-13-2011, 02:40 PM
yes nuts. the nut turns but doesn't come any farther off. so the socket turns the nut and bolt
Old 01-13-2011, 02:54 PM
Senior Member
Superman's Avatar
Are you sure the stud is turning? Either the threads are stripped and the studs are not turning, or the studs have come un-welded.
Mocha 1978 911SC. "Coco"
Old 01-13-2011, 03:15 PM
yes it is. and on closer inspection the nut on it appears to be different from the other 3. what size are the nuts? because i don't seem to have anything that fits snugly.
Old 01-13-2011, 03:41 PM
D911SC's Avatar
When I removed my bumper 3 came off easy but one was spinning like yours. As suggested the weld came off and left behind a neat hole - almost like it was supposed to have a nut and bolt.
I expect yours is the same. When you reassemble you can simply use a nut and bolt or reweld a threaded rod (or bolt) back onto the bumper shock. I'm pretty sure the nut is an M10.
It's an easy fix.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 01-13-2011, 04:01 PM
It's an easy fix.
how did you get the last one off?
Old 01-13-2011, 04:03 PM
D911SC's Avatar
Mine just came out when I tried removing the nut.
If this doesn't work you might be able to tap it out or in the worse case cut it off. I had a few rusted nuts and bolts where I used a dremel. In your case you could cut it, use a 10mm drill bit to redo the hole and then use a fresh nut and bolt.
BTW - I edited my previous post with nut size of M10
Old 01-13-2011, 04:10 PM
found out one way to do. turned a little and then snapped off. guess i didn't use quite enough Blaster.
Old 01-13-2011, 04:53 PM
