scotricker's Avatar
Re-Checking my Valve Adjust.. Do I need to drain all the oil?
I just did my first valve adjust on the 911 last week. It sounds a little noisier than I am comfortable with, so I'd like to go in and check tham all again. I think at least one of them is too loose.
So can I just drain the oil from the engine sump and leave the tank? Or should I drain both places before pulling the valve covers?
In either case, I will use a clean catch pan and plan to re-use the oil. OK?
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 01-22-2011, 12:35 PM
arbita1's Avatar
No...you you only need to drain the oil at the engine sump. The tank can stay.
I wouldn't re-use the oil unless it's a brand new catch pan. If you've used it before, then it has dirty oil in it and will contaminate the clean oil. I'd say it's good practice to just use new oil regardless. Maybe others will have different opinions on this one.
Matt.
83 911SC
85.5 944 NA - Sold
Old 01-22-2011, 12:50 PM
Oil is cheap . . . your engine is not. Top off with new oil.
Mike White
1972 911E Coupe (with 2.7 and 40 IDS and SSI)
Old 01-22-2011, 01:13 PM
haycait911's Avatar
I saw a thread once where they lifted one side of the car to do the valves and didn't lose much oil at all.
Old 01-22-2011, 02:04 PM
Arrow
I do it this way, you just have to do one side then the other so there is a little more rotation involved.
Start with the left side of the car up. Set #1 at TDC, adjust the valves and then rotate 240 deg. to #2, then 240 deg to #3. Double check clearences then button up the left side, lower the car.
Then move to the right side, lift the car, rotate the crank so that #4 is TDC and adjust #4 then 240 degs in sequence to #5 and #6. Double check and done.
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-22-2011, 03:44 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Thats exactly how most do it. You wont lose any oil except for some drips..
Old 01-22-2011, 03:57 PM
carreradpt's Avatar
Do you use new nuts and gaskets then, in his case?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 01-22-2011, 04:33 PM
muck-raker
kidrock's Avatar
definitely use new gaskets and nylock nuts and associated washers.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-22-2011, 04:38 PM
80-911SC's Avatar
yes ... unless you have the red gaskets ...... but new nuts are still recommended ....
Old 01-22-2011, 04:41 PM
brads911sc's Avatar
reusing oil would be a bad decision.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-22-2011, 07:23 PM
I usually end up losing about 1 quart, by this method. Maybe I am not lifting it high enough.
Old 01-22-2011, 08:51 PM
scotricker's Avatar
thanks, ok, new hardware, red gaskets, new oil, and I'll try the tippy method
Scot
Old 01-23-2011, 10:35 AM
arbita1's Avatar
Correct me if I'm wrong. Does he really need to replace the gaskets and hardware if they are all brand new?
I had a similar situation last summer where I had to go back in and readjust the valves right after. I was told if I didn't rip the gaskets I could reuse everything since it was all new.
Matt.
83 911SC
85.5 944 NA - Sold
Old 01-23-2011, 10:41 AM
Matt,
Do you have any leaks? For someone who does thier own maintenance and is in and out of thier valve covers frequently then it make sense to use the reusable gaskets, and they probably wont have any issues using the nuts and washers two or even three times.
However when one is going 10 K in between valve jobs then they should be changed.
The key components of this decision is money, time and risk.
The nylock 13mm nuts may back out when worn so you must check them frequently if you decide to reuse them.
Shane
Old 01-23-2011, 12:31 PM
arbita1's Avatar
Originally Posted by snbush67 View Post
Matt,
Shane
Yes. I have some leaks...but not from the valve covers. I agree that everything should be replaced when you are doing your 10 - 15K mile valve adjust. (which I do). However, he only has a week on his gaskets/hardware (so probably hardly any miles). To me it just seemed wasteful to buy new stuff, that's why I was asking.
Matt.
83 911SC
85.5 944 NA - Sold
Old 01-24-2011, 04:27 AM
