Irrationally exuberant
ChrisBennet's Avatar
Brake fluid overflow drain goes where?
Hi everyone,
My friend Moe and I are restoring his Euro '74 911 and we can't figure out where the drain for the brake fluid overflow goes though the bottom of the car. On this car the brake fluid overflow line joins the vent for the gas tank vapor tank and then the shared tube goes someplace. On a "normal" US car, the gas vapors are drawn into a charcoal canister. THIS CAR DOES NOT HAVE A CHARCOAL CANISTER OR ANY VACUUM OR PRESSURE LINES GOING UP FRONT.
Moe replaced the front pan so perhaps the hole for the tube disappeared with the old pan.
TIA,
Chris
Old 02-03-2002, 05:42 PM
pwd72s's Avatar
On PRE '74 models, the tube exits behind the front bumper. I've made an extension for mine, ran it through the front torsion bar protective plate and let any fluid exit underneath from there. Look almost directly up from the torsion bar, see if there might be a hole in the trunk metal, behind the bumper? That's where you'd find the exit in a PRE '74. May or may not be there in your car, but worth a look?
Old 02-03-2002, 05:48 PM
In my US spec '76 the brake vent/overflow drain goes through one of the plastic plugs (the one on the driver's side) in the panel behind the front bumper. I'm not sure about the ROW spec but in the US '74 models the tank vent went to the back of the car to a charcoal cannister and attachment to engine. Perhaps in the ROW the lines join and go out the front panel plastic plug. Jim
Old 02-03-2002, 06:02 PM
Thanks pwd72s,
I asked a friend with a '73 and got the same answer. Any Europhiles out there?
Chris
Old 02-03-2002, 06:05 PM
cary's Avatar
Right out the front just like everyone esles. 77 Carrera 3.0.
Make sure you use the "red" braided hose. It is the brake fluid proof stuff. And the little elbow dohicky. ( technical term ).
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 02-03-2002, 06:10 PM
cary's Avatar
Just took this JPEG for search/future reference.
Brake System Vent
Cary
73 914S 2.0 AG
Old 04-01-2002, 01:38 PM
Cary,
I can't tell what I'm looking at there. This is kinda important to me. I'm not just razzing you. Well, not yet at least.
-Chris
Old 04-01-2002, 01:49 PM
cary's Avatar
Ok my feelings are hurt ..........
The damn battery went dead in the camera yesterday.
I have the front bumper off to put the IROC/RS bumpers on. What you have is the close up. But if you'd don't know where it is, that won't help much.
I'll shoot a couple more tonight.
Cary
73 914S 2.0 AG
Old 04-01-2002, 02:00 PM
So this is behind the front bumper. That helps some. thanx
Old 04-01-2002, 02:05 PM
cary's Avatar
I'll shoot one inside by the battery where it goes thru. And a wide view of the front. To give you the location.
Cary
73 914S 2.0 AG
Old 04-01-2002, 02:35 PM
cary's Avatar
10,000 words
Coming out of the MC
Going thru front tub
Front View
Cary
73 914S 2.0 AG
Old 04-01-2002, 06:09 PM
pwd72s's Avatar
Wow Cary. You, most assuredly, have "been there, done that"...
Old 04-01-2002, 06:16 PM
Baby, you're the greatest!
super thanks,
Chris
Old 04-01-2002, 06:17 PM
cary's Avatar
Glad I could help.
Remember you have to use the RED hose. Brake fluid will melt the regular stuff. Part # N 020.361.2 Bulk Vent Hose 4 * 1.5mm.
Hose Routeing
Cary
73 914S 2.0 AG
Old 04-01-2002, 06:58 PM
cary's Avatar
Scared Me ...........
After I looked at the JPEG. I had to run out to the garage ...and look at that battery corner.
Cary
73 914S 2.0 AG
Old 04-01-2002, 07:08 PM
Red hose eh? My friends '74 came from the factory with some sort of clear stuff. I have some blue braided brake hose like you use to connect the reservoir to the master cylinder.
The added photos were extremely helpful.
many thanks,
Chris
Old 04-01-2002, 07:22 PM
