haycait911's Avatar
engine noise has me stumped - any thoughts?
(**ALL BETTER NOW***) a squeeky noise, sounds rotational, changes with engine speed. clutch engagement doesn't change it, nor does removing alt belt. only things I did to the engine lately were a tensioner update and a valve adjust. the engine pulley isn't contacting anywhere. poured some oil into the dizzy. no change. there's a limited number of rotating things on the outside of a 911 engine. could be a chain noise of some sort but I can't imagine what. my next thing will be removing the engine pulley and tins. no mfi drive on the cam.
have a listen......................
YouTube - 001
YouTube - 002
Old 01-31-2011, 08:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Have you checked your fan belt? When I over tightened mine, it squeeled like a pig.
One shim in no more Squeel.
Oops nevermind you pulled the belt :?:
'85 Carrera Targa
PCA/POC
Old 01-31-2011, 08:49 PM
DRACO A5OG's Avatar
Watched Vid, have checked under the car? Maybe exhaust leak/loose bolt?
Sorry can't be more helpfull.
'85 Carrera Targa
PCA/POC
Old 01-31-2011, 08:53 PM
DRACO A5OG's Avatar
Sorry to be so annoying, one more brain fart:
Did put a stethoscope near the upgraded tensioners?
'85 Carrera Targa
PCA/POC
Old 01-31-2011, 08:57 PM
haycait911's Avatar
thanks for the thoughs. Draco, you got me on the right track. looked underneath but didn't sound like an exhaust leak, I've had plenty of those. so I looked at the other end. a little spraying of quick start at the intake manifold gaskets told the tail. I've never had an intake leak before, sure sounds like a belt or sheetmetal squeek. anyway, it appears some genius didn't tighten the manifold to head nuts very well. or let's say the gaskets squished a bit and allowed a leak, yeah.that's right . anyway, tightened nuts and all's well. took longer to load the videos than the fix took. thanks much, Don.
Old 01-31-2011, 09:04 PM
Did you check your distributer? Look under the cap?
Old 01-31-2011, 09:05 PM
Warren Hall Student
Bobboloo's Avatar
Considering the last thing you did before it started was the tensioner upgrade and valve adjustment so I would look there.
Pull the valve covers and take look inside. Make sure you didn't leave something inside. Also pull the chain box covers and inspect there as well.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 01-31-2011, 09:07 PM
DRACO A5OG's Avatar
Oh cool, He Fixed It!
'85 Carrera Targa
PCA/POC
Old 01-31-2011, 09:14 PM
Warren Hall Student
Bobboloo's Avatar
Congrats. Maybe it was one of the stacks rockin.
Bobby
Old 01-31-2011, 09:16 PM
