engine noise has me stumped - any thoughts?
(**ALL BETTER NOW***) a squeeky noise, sounds rotational, changes with engine speed. clutch engagement doesn't change it, nor does removing alt belt. only things I did to the engine lately were a tensioner update and a valve adjust. the engine pulley isn't contacting anywhere. poured some oil into the dizzy. no change. there's a limited number of rotating things on the outside of a 911 engine. could be a chain noise of some sort but I can't imagine what. my next thing will be removing the engine pulley and tins. no mfi drive on the cam.
have a listen...................... YouTube - 001 YouTube - 002 Last edited by haycait911; 01-31-2011 at 08:06 PM.. |
Member 911 Anonymous
Have you checked your fan belt? When I over tightened mine, it squeeled like a pig.
One shim in no more Squeel. ![]() Oops nevermind you pulled the belt :?:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Watched Vid, have checked under the car? Maybe exhaust leak/loose bolt?
Sorry can't be more helpfull.
Sorry to be so annoying, one more brain fart:
Did put a stethoscope near the upgraded tensioners?
thanks for the thoughs. Draco, you got me on the right track. looked underneath but didn't sound like an exhaust leak, I've had plenty of those. so I looked at the other end. a little spraying of quick start at the intake manifold gaskets told the tail. I've never had an intake leak before, sure sounds like a belt or sheetmetal squeek. anyway, it appears some genius didn't tighten the manifold to head nuts very well. or let's say the gaskets squished a bit and allowed a leak, yeah.that's right
Did you check your distributer? Look under the cap?
Warren Hall Student
Considering the last thing you did before it started was the tensioner upgrade and valve adjustment so I would look there.
Pull the valve covers and take look inside. Make sure you didn't leave something inside. Also pull the chain box covers and inspect there as well.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Oh cool, He Fixed It!
Warren Hall Student
Congrats. Maybe it was one of the stacks rockin.
Thread Tools | |
Rate This Thread | |
