Is there aBolt In Roll Bar with removable cross brace?????
Been looking at Das Sport bolt in roll bars but it appears a pain to keep taking in and out so the rear passenger area can be used when not at a DE.
Does anyone make a bolt in roll bar........that the main hoop can be left in place....but remove the diagonal and harness bar so the rear passenger area can be used?
Old 02-03-2011, 06:02 AM
tobluforu's Avatar
Auto power.
Old 02-03-2011, 06:13 AM
Originally Posted by tobluforu View Post
auto power.
+1
Old 02-03-2011, 06:18 AM
Limbo
Slider79SC's Avatar
Check Safety Devices. Mine fits very well in the car. However, I have the fixed cross brace.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 02-03-2011, 06:46 AM
Plavan's Avatar
Depending on what you want to do (Race, DE etc) make sure they have the correct specs. I heard that some people had problems with Safety Devices cages not passing SCCA tech.
YMMV
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-03-2011, 07:22 AM
Its for PCA DE use only.
Cross brace will be removed for street use
Old 02-03-2011, 09:06 AM
Now in 993 land ...
aigel's Avatar
Safety Devices. Their stuff is expensive but they are the best IMHO. They tie into the body better and with proper weld in bolt plates.
G
Roll Bar, 911 Coupe -1989 PCA Legal-Stable Energies
81 SC (sold)
Old 02-03-2011, 11:34 AM
Limbo
Slider79SC's Avatar
Safety Devices Install - with removable seat back cross brace.
I thought my croos brace was a welded in piece but I am a moron today..... Too dang cold here to think straight
To get everything properly lined up you do have to put the cage in and out several times if you want a real nice fit.
I installed mine without the floor ("frame rail") plates first and marked all the holes to be drilled.
I then drilled the "rails" for the plates, set them in place and re-installed the cage. I then bolted the plates to the cage floor plates and tack welded each plate on four corners to the frame "rails".
This insured that the cage was exactly where I wanted it to be. I then removed the cage and did all the final welding. After that it was time to put the cage in for the last time and leave it.....
Old 02-03-2011, 12:32 PM
Limbo
Slider79SC's Avatar
Plates welded and sealed:
Here are the pics of how tight this fits in the car:
Old 02-03-2011, 12:38 PM
