1969 912 (2.4l 1973.5)
ppanagis@gmail.'s Avatar
Send a message via Skype™ to ppanagis@gmail.
Hey Joe Bob... get one of these .. The fuchs you have give pletty of room to get in the corners. Not like deep sixes....
Old 02-16-2011, 08:34 AM
RETIRED
Joe Bob's Avatar
What is it? Where to get it?
2012 ML350 3.0 Turbo Diesel
Old 02-16-2011, 08:35 AM
I get them at the Canadian version of your Pep Boys but on line i found this you may look at.4" Diameter Abrasive Scotch Brite Ball 80 grit aluminum oxide
I use this in combination with 3m scotch bright sanding pads and it gets the job done. there are red pads and grey pads... the grey pad is final step before polishing ... ask for them at car parts store... Also if you have deep groves you need to be taken out of the metal. sanding disks should be used first.
Old 02-16-2011, 08:42 AM
m1franck's Avatar
Slather on the aircraft paint stripper, then cover the wheel with saran wrap or put it in a white plastic garbage bag. Sealing off the wheel helps the stripper work better. Also, make sure the work space you are doing this in is not too cold, but for crap sake don't do this in a garage that's attached to your house or has the furnace located in the garage. The wife will be really pissed when the inside of the home smells like that nasty paint stripper!
Also, a pressure washer helps to blast the paint off the wheel once the paint stripper has softened it up. I've had to do 4 - 5 layers of stripper to get all of the paint off of a wheel. It still beats sanding by hand.
Old 02-16-2011, 08:47 AM
Results of the finish using scotch bright pads
Finally i clear coated the wheels to protect them
Old 02-16-2011, 08:53 AM
muck-raker
kidrock's Avatar
If I see the word "stripper" one more time, I'm going out to break a 'c' note into singles.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-16-2011, 10:27 AM
RETIRED
Joe Bob's Avatar
I'll pick up the "sex worker in a can" manana......
Old 02-16-2011, 10:33 AM
French Import
zippy_gg's Avatar
Must support single moms!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-16-2011, 11:56 AM
French Import
zippy_gg's Avatar
Thumbs up
You are so hired! Awesome results!
Can you give some details on how you painted the centers and what you used...?
Gilles & Kathy
Old 02-16-2011, 11:57 AM
RETIRED
Joe Bob's Avatar
I've done a few paint jobs on Fuchs.....when I was changing colors of side graphics every couple of months. Blue ( low glue residue) masking tape and color matched rattle can Krylon. I've had wheels in Gulf Blue, Emerald Green, Guard's Red, GP white, black and just polish......I prefer the clean look.....hence the total strip.
If you are gonna be a concours weenie (CW), Wurth Satin. A nice clear over it....well, I don't like clear. I prefer a single stage paint and then the ability to polish the rest. Clear can yellow in the UV light. It's getting worse now with the low VOC crap being forced on the hobbyist.
Powder coating is an option but the high heat needed to cure the product can effect the forged wheels. Rumor has it the heat is as bad as chroming. PC is also REAL tough to get off if you wanna do a strip and color change.
I've had as many as 4 different colors before stripping. I also never found the need for primer.
YMMV
Old 02-16-2011, 12:14 PM
Sure... i used Oil based Tremclad paint... First a primer it was actually brown. No need to use zinc oxide primer i was told. then Tremclad satin black... the final clear coat was duplicolor clear coat for mags.
Old 02-16-2011, 08:20 PM
'87 Targa
Posting my question here because it isn't really about polishing or refinishing, just yet. And, my question isn't so much about cleaning brake dust as it is grinding down through the brake dust, etc. This topic seems closest (without starting a new one).
I have a set of Fuchs that were refinished with "Polished Lips" decades ago. Unfortunately, the polished lips did not have a protective finish, and the brake pads I used were rather dusty and corrosive.
So, here's what I got (below). I intend to get them properly restored, but I'm not quite ready, yet. Meantime, how can I best polish out the brake dust and surface corrosion. Are there any preferred tools and compounds? Super big thanks for any suggestions!
Old 11-01-2025, 03:14 PM
Grey 3M Scotchbrite pads, and Mother's Mag & Aluminum polish.
Is that pitting, or just brake dust stuck to the wheel?
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 11-01-2025, 04:29 PM
Full Send Society
Save yourself a headache and have them glass bead blasted. The finish will be prime for painting or other refinishing and it’s fast and thorough.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 11-01-2025, 06:17 PM
'87 Targa
I thought it was worse than it is. I took a green scotchbrite (because that's what I had) to a small spot for 30-sec. Most of it cleaned off easier than I remember. But, there is some pitting. Not deep, just surface, but...
I'll look for some gray scotchbrite. And, I'll look into bead blast services. Thanks for the suggestions Dave and Julian.
Old 11-02-2025, 09:48 AM
PCA Member since 1988
Save yourself even more headache. Make those your "winter wheels" and buy a better set for stylin'.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-03-2025, 05:06 PM
I bought 4 of 930 wheels years ago. Basically the black center was not too bad but lips call them were nasty.
I attacked mine with wet dry sand paper. Probably started with something like 220. Eventually getting finer to guessing now 1000 to 1500?
Been over 20 yrs. Used Flitz or any other sort of course metal polish and now a mirror finish.
Will see is able to attach a picture?
Old 11-07-2025, 07:04 AM
Old 11-07-2025, 07:18 AM
