I did my own version of Elephant racings strut brace
I wanted to have some sort of strut brace in my car, but didn't want to loose all of the luggage compartment. I then saw Elephant racings "QuickChange" strut brace system and thought the concept was really nice.
![]() I thought this could be done with some metal fabrication, some turnbuckles cut in the middle and extended, and this is the result: ![]() Starting with: ![]() ![]() ![]() ![]() ![]() ![]() ![]() And all the turnbuckles cut in half and extended with some pipes from work
Dennis Johansen PCS 3413 Porsche 911 SC -83 SCWDP member #0004 Saab 900 -88 Vinga Edition Last edited by Cyberdennis; 02-15-2011 at 09:37 AM.. |
Very nice work...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Max Sluiter
Good for you, but beware any wrath from Chuck.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Ooooooooooooh........
Dennis Johansen PCS 3413 Porsche 911 SC -83 SCWDP member #0004 Saab 900 -88 Vinga Edition |
coolcavaracing.com
Nice work Dennis...
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Gentle critique....there is not enough rear-ward bending resistance with the extended sheet metal piece which captures the rear mounting if the "X" cross braces.
![]() Can be considerably improved if there is a horseshoe shaped piece that connects this horizontal-plane section also to the front shock tower bolt. Or...if the side-view "L" shape was maintained for its entire width, instead of the "L" being cut-down to result in the "flat-only" section we see at the back-side of the tower. It would be an improvement.... yet still be somewhat weak in the up-and-down bending direction. That aspect can be improved with some sort of vertical boxed component. Might need another "L" section maybe vertically-too. Best would be not to use an extended metal piece at all and try to triangulate on the flat horizontal plane directly to the shock tower bolt. That original bolt location on the tower itself, is stiff horizontally and vertically. Another thought is to bring the entire bolted section much closer to the shock tower, and not have it hanging in space inside the trunk area as it does now. I understand why it was done,....to gain bolting access....but it severely reduces its effectiveness. Great looking and tidy workmanship.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-15-2011 at 12:06 PM.. |
I'm just happy i got it all together in the end
.If i notice that somethings won't work (on my street/trackday car, not race car), I might try again with some new parts. The second prototype won't take that long to make .
A picture with better quality:
Nice work. I concur as to what Wil said about the strut tower brackets.
The tubes look to be steel. If so, 5 tubes become weighty. If you get to V2, try tapered tubes and rod ends in aluminum. Sherwood |
I often wonder how effective ANY of this stuff is for a street car...as we have a whole lot of rubber in various places being compressed and extended....the torsion bar rubber bushes, the top shock mounts, etc, etc....before we need to start worrying about millimeter type deflection of the sheet metal.
That said.... a simple change that would increase bending resistance, and to avoid any welded fabrication of the pieces, would be to 1.) Move the mounting holes as much toward the shock tower as you can, to minimize the "overhang" into space... 2.) to use a pure "L" shape for the entire length ( width, as installed in the car) of the original bracket, and finally 3.)...to use another "L" shaped piece back-to-back against the original one...suitably bolted together in various places to avoid welding for the home mechanic.... Something like this, as an idea---> ![]() The red line shows the extension of the original bracket to maintain the "L" shape for its entire length ( "width"..as installed in the car) and the yellow line is the starting view of the mirror-image "L" shape piece bolted-onto the backside of the original piece. The red holes suggest moving closer to the shock towers. This is only a first thought suggestion and can itself be improved.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-15-2011 at 12:53 PM.. |
A few more pictures with the tubes connected:
![]() ![]() The torsion bar bushings are no longer rubber and I know there are more areas that affect the flex of the car, but you have to start somewhere... The reason I used steel tubes is that i got the turnbuckles with left- and righthanded threads and quick connectors at a good price and just wanted to see if I could make something like Elephant racings quick connect system cheap and working in the same way. I love taking something made for a complete different area and use it for something on my car, in this case from the marine area ![]() Thanks for all your suggestions but I will start the season with my setup and see what happens
AutoBahned
do you have the # hours you put in? and the cost of the parts?
my guess is there will not be any "Chuck Wrath" since the costs to do this for nearly everyone else will be fairly high |
Why is there a need to brace to the front of the trunk? Given the locations of the ball joints on the a-arms there isn't much load transmitted to the fronts of the a-arms during cornering. The only loads the fronts of the a-arms will really see is tension across the front of the car during braking.
Now in 993 land ...
Nice fabrication.
I would love to see someone put strain gauges on such a set up and see what load actually goes onto these bars. That should give us a better idea if they are worth the $ or in this case the time. I have a straight brace on my 993 and had one on my SC but for sure don't know if it made a difference or not. G |
72 911 Although it is done at the moment, it will never be finished. |
AutoBahned
I'd also love to see some strain gage data...
w/o that, the next step down is to think about what Porsche AG did on their production cars and race cars... after that, you can rely on "clinical experience" - i.e. how the thing feels, esp. useful if a double blind test is done (but it won't be)... |
Great excution.......but and just a question.....
Shouldn't the mounting be directly on the strut towers since thats where the suspension is moving and where the stress will be? I was always under the impression strut tower braces were designed to work off each strut to keep the suspension geometry the same under load.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
Nice work, gusset the intersection of the "X" ??
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Schleprock
Kevin L '86 Carrera "Larry" |
