RETIRED
Joe Bob's Avatar
4 wire versus 3 wire O2 sensor.
Correct me if I'm wrong.....the difference in the 3 and 4 wire O2 sensors is that the 3 wire grounds thru the case of the sensor....while the 4 wire has an extra ground wire?
It's a Mazda/Chrysler thing from what I see on the net...
So as long as the grounds and power are correct and the sensor fits the bung, a four wire can be used? Reason I ask, I was able to pick up a number of NIB Bosch 4 wires for real cheap....
2012 ML350 3.0 Turbo Diesel
Old 02-18-2011, 05:40 PM
Senior Advisor
James Brown's Avatar
yes, you don't have to use the heater elements. are these wide band O2 sensors?
08 Cayenne Turbo
Old 02-18-2011, 06:38 PM
RETIRED
Joe Bob's Avatar
I WANT to use the heating elements. It's a good thing......
Old 02-18-2011, 07:42 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
The heater portion of a 4 wire 02 sensor is monitored by OBDII vehicles. If youre putting this on anything older than a 96 model, its irrelevant.
Old 02-18-2011, 07:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Why not just get a Ford Taurus O2 Sensor, proper 3 wire.
'85 Carrera Targa
PCA/POC
Old 02-18-2011, 08:17 PM
RETIRED
Joe Bob's Avatar
I would but I have two 4 wires that I got for cheap. Just looking to see if there is any downside on using them....I don't have an OBD engine as it's a 93. But it IS wired for a heated 02.
Old 02-18-2011, 10:12 PM
DRACO A5OG's Avatar
Won't the O2S ground itself when bolted in?
'85 Carrera Targa
PCA/POC
Old 02-18-2011, 10:57 PM
Yep, I've done that!
joeblow's Avatar
The 4-wire is a still narrow band O2 with the 4th wire being a signal ground. The signal is only a 0-1V range and simple temperature changes alone can alter the output using the exhaust as the signal ground.
Going to a 4-wire, and actually running the signal ground right to the DME ground point is ideal but simply running a good ground wire to a known chassis ground or to the neg post on the battery are still far better than using the 3-wire grounded through the exhaust.
A narrow band 4-wire can be very accurate and significantly faster responding than a 3-wire. If I was having a hard time passing an emissions test this is one thing I would do.
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 02-19-2011, 04:56 PM
