RETIRED
4 wire versus 3 wire O2 sensor.
Correct me if I'm wrong.....the difference in the 3 and 4 wire O2 sensors is that the 3 wire grounds thru the case of the sensor....while the 4 wire has an extra ground wire?
It's a Mazda/Chrysler thing from what I see on the net... ![]() So as long as the grounds and power are correct and the sensor fits the bung, a four wire can be used? Reason I ask, I was able to pick up a number of NIB Bosch 4 wires for real cheap....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 02-18-2011 at 05:43 PM.. |
Senior Advisor
yes, you don't have to use the heater elements. are these wide band O2 sensors?
08 Cayenne Turbo |
RETIRED
I WANT to use the heating elements. It's a good thing......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Insert Tag Line HERE.....
The heater portion of a 4 wire 02 sensor is monitored by OBDII vehicles. If youre putting this on anything older than a 96 model, its irrelevant.
Member 911 Anonymous
Why not just get a Ford Taurus O2 Sensor, proper 3 wire.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
I would but I have two 4 wires that I got for cheap. Just looking to see if there is any downside on using them....I don't have an OBD engine as it's a 93. But it IS wired for a heated 02.
Won't the O2S ground itself when bolted in?
Yep, I've done that!
The 4-wire is a still narrow band O2 with the 4th wire being a signal ground. The signal is only a 0-1V range and simple temperature changes alone can alter the output using the exhaust as the signal ground.
Going to a 4-wire, and actually running the signal ground right to the DME ground point is ideal but simply running a good ground wire to a known chassis ground or to the neg post on the battery are still far better than using the 3-wire grounded through the exhaust. A narrow band 4-wire can be very accurate and significantly faster responding than a 3-wire. If I was having a hard time passing an emissions test this is one thing I would do.
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
