blast cabinet tech - or - most embarassing moment?
I've been using my blast cabinet with glass beads to clean up some aluminum parts. works beautifully, cleans the alum without damaging the surface. soda blasting is a bit nicer to tough to manage without the proper, and expensive, equipment.
I was having a problem with static build-up. I was getting a lot of static charge building up in the cabinet then jumping to the closest points of my body to the cabinet. usually my chest ( nipples) and lips ( as I was looking through the window). this was understandably annoying with the latter, and not at all as pleasant as some might think with the former. after some thought I figured I needed to ground my skin to the cabinet. the only way I could really see to do that was to hike my shirt up around my armpits and lean my chest (nipples) against the cabinet. well, it worked great! no more shocks at all. so I'm happily blasting away on my parts when my wife walks into the garage. only to find me with a naked chest and in a compromising position with my blast cabinet. what can one really say in a situation like that. anyway, FWIW this method does eliminate static shock but may cause talk. |
French Import
Remember: What happens in the privacy of your garage stays on Youtube... forever!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Bird. It's the word...
The nipples have many pleasure nerves...
John Forcier Current: 68L 2.0 Hotrod - build underway |
Now that's thinking outside the box. Personally, I would have started with one of these...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
UnRegistered User
Nothing like having a second set of eyes on your work..
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Easily Confused
Find a good electronics shop and get a static wrist strap. Ask for an ESD (Electro Static Discharge) strap/cable.
Connect the strap to the blast cabinet chassis and attach it to your wrist. This will shunt the charge to ground before it reaches more *ahem* sensitive parts of your body.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
sometimes your tools just need a good hug............................it's so lonely in the garage.
Regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Northern Motorhead
Wow !
I have to go try that with my cabinet ... lol Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
If your wife were using the cabinet I'd say post some pics, but in this case I'd say just connect a wire from the cabinet to the nearest copper pipe or electrical ground.
Ed 1973.5 T |
Senior Advisor
Yes you have to ground or bond the nozzle to the cabinet and then to a good ground in the garage. you can use common wire like 12 gage. This is a common problem.
08 Cayenne Turbo |
good thing you had pants on or the shock could have diverted lower ...
Cue the 70's music...
Bow chicka bow wow. |
Whadda bunch of prudes...static discharge wrist bands? Please...
Nipple clamps with a chain attached to the cabinet...that's how real men do it: ![]() P.S. - Google "nipple clamps" when the kids are out of the room... |
Sherwood |
RETIRED
Ground straps connected to the equipment and a ground pole stuck in the soil outside, extra around your ankles/calves dropping to the floor....
You other guys are sick.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Man up and use jumper cables....
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
What happens in the shop, stays in the shop..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Caveman Hammer Mechanic
Nipple Clamps & Toys - BDSMStore.com BAAAHAAAA eric P.S. Not P.G.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
this is pretty funny
I was lucky enought to get a cleanroom ESD grade rubber floor in my garage (work was throwing it away) would have cost $5k+ to buy and no one would ever do it.... but I have it
