911SC Hobbyist
Been a while but I found out what my knock was
Well it has been a while since I posted anything and now I have the heads off the engine and have found the problem.
wow who would have thunk a small machine screw could do so much damage.
Look like I need a sleeve, Cylinder head and piston.
any comments are appreciated.
Old 02-26-2011, 02:23 PM
UnRegistered User
billybek's Avatar
How did it jump in there?
Good that you found the problem.
Bill K.
Old 02-26-2011, 02:38 PM
911SC Hobbyist
dont know but I have the offender. this is probably gonna cost me an arm to fix.
Old 02-26-2011, 02:42 PM
Senior Advisor
James Brown's Avatar
The good (kinda) news is you just need one of each, there usually cheaper because no one needs just one. Someone might just have one kicking around the garage and make you a good deal.
Most likely a small screw fell in around the spark plug and when they were pulled, it fell in. Or it fell in via the induction system.
08 Cayenne Turbo
Old 02-26-2011, 03:13 PM
Flat Six
Flat Six's Avatar
Did the same thing about 30 years ago w/a Fiat 850. Dropped a small nut down the carb throat, made it all the way past an intake valve and embedded in a piston crown. At least it was a Fiat and not a P-car.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 02-26-2011, 05:41 PM
I think you should let your wife sand down the bad spots with some sandpaper and see I'd that helps .she loves you alot and would do anything to hep I am sure .
Old 02-26-2011, 06:58 PM
Shaun @ Tru6's Avatar
an 850 would have rusted away before you got the head off.
Tru6 Restoration & Design
Old 02-26-2011, 07:08 PM
CorsePerVita's Avatar
Hooooly! Wow that's no fun! Hope the replacement goes well! Sorry to hear that.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 02-26-2011, 07:09 PM
All those black coated dilivars?
All those pieces are readily available..
Bruce
Old 02-26-2011, 07:13 PM
Hey buddy you should just buy a another engine I am sure your wife would want you to.
Old 02-26-2011, 07:20 PM
911SC Hobbyist
thanks peachy for the ideas but it needs to be done correctly and this is an area that my wife cannot help.
If only I knew where I could get all this. if anyone has this lying around I would sure like to know.
Old 02-26-2011, 08:33 PM
911SC Hobbyist
alright parts ordered. now it is a waiting game to see when they come in.
guess I should re-ring it also.
Old 02-28-2011, 06:41 AM
ratpiper71T's Avatar
Is it just me or does this photo show a lot of loose metal debris fallen down in to the engine? It seems like you are planning to replace said damage and reseal?You might want to post on the engine rebuilding forum and quiz the resident experts there whether or not that would be wise.
Metal chunks have been floating around in your oil passages for as long as you've had this problem. You need to ask the experts whether it's even safe to assume you could clean enough of it out and reseal. The consequences could be even worse.
Good luck.
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 02-28-2011, 09:20 AM
Flat Six
Flat Six's Avatar
. . . rust was the only thing holding it together anyway. Well, some duct tape and JB Weld, too. After working w/Marelli electrics, made me wish they were Lucas instead!
Dale
Old 02-28-2011, 10:43 AM
911SC Hobbyist
Ratpiper71T,
what you are seeing is a reflection of the silver indentions in the piston itself. I did not find any metal shards in the cylinder itself. interesting but i believe that the piston just kept beating that darn sheetmetal screw into the head and the piston over and over again.
Old 02-28-2011, 04:03 PM
Youre looking at KS brand, I wouldnt re ring alucil.
Bruce
Old 03-01-2011, 02:01 PM
911SC Hobbyist
parts are in and I am waiting on the ring compressor to come in.
Bruce,
can you recommend some kind of a solvent to clean up the pistons and heads?
Mike
Old 03-08-2011, 07:13 AM
Now in 993 land ...
aigel's Avatar
I always dip my parts in a bucket of this to get them nice and clean. Wash with water and then final clean with brake parts cleaner. Pistons and rings get dipped in trans fluid for assembly lube.
G
81 SC (sold)
Old 03-08-2011, 09:16 AM
