911SC Hobbyist
Been a while but I found out what my knock was
Well it has been a while since I posted anything and now I have the heads off the engine and have found the problem.
wow who would have thunk a small machine screw could do so much damage. Look like I need a sleeve, Cylinder head and piston. any comments are appreciated. ![]() ![]() ![]() ![]() ![]()
UnRegistered User
How did it jump in there?
Good that you found the problem.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
911SC Hobbyist
dont know but I have the offender. this is probably gonna cost me an arm to fix.
Senior Advisor
The good (kinda) news is you just need one of each, there usually cheaper because no one needs just one. Someone might just have one kicking around the garage and make you a good deal.
Most likely a small screw fell in around the spark plug and when they were pulled, it fell in. Or it fell in via the induction system.
08 Cayenne Turbo Last edited by James Brown; 02-26-2011 at 03:16 PM.. |
Flat Six
Did the same thing about 30 years ago w/a Fiat 850. Dropped a small nut down the carb throat, made it all the way past an intake valve and embedded in a piston crown. At least it was a Fiat and not a P-car.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
I think you should let your wife sand down the bad spots with some sandpaper and see I'd that helps .she loves you alot and would do anything to hep I am sure .
Tru6 Restoration & Design |
Hooooly! Wow that's no fun! Hope the replacement goes well! Sorry to hear that.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
All those black coated dilivars?
All those pieces are readily available.. Bruce |
Hey buddy you should just buy a another engine I am sure your wife would want you to.
911SC Hobbyist
thanks peachy for the ideas but it needs to be done correctly and this is an area that my wife cannot help.
If only I knew where I could get all this. if anyone has this lying around I would sure like to know. |
911SC Hobbyist
alright parts ordered. now it is a waiting game to see when they come in.
guess I should re-ring it also. |
![]() Is it just me or does this photo show a lot of loose metal debris fallen down in to the engine? It seems like you are planning to replace said damage and reseal?You might want to post on the engine rebuilding forum and quiz the resident experts there whether or not that would be wise. Metal chunks have been floating around in your oil passages for as long as you've had this problem. You need to ask the experts whether it's even safe to assume you could clean enough of it out and reseal. The consequences could be even worse. Good luck.
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound! |
Flat Six
911SC Hobbyist
Ratpiper71T,
what you are seeing is a reflection of the silver indentions in the piston itself. I did not find any metal shards in the cylinder itself. interesting but i believe that the piston just kept beating that darn sheetmetal screw into the head and the piston over and over again. |
Youre looking at KS brand, I wouldnt re ring alucil.
Bruce |
911SC Hobbyist
parts are in and I am waiting on the ring compressor to come in.
Bruce, can you recommend some kind of a solvent to clean up the pistons and heads? Mike |
Now in 993 land ...
I always dip my parts in a bucket of this to get them nice and clean. Wash with water and then final clean with brake parts cleaner. Pistons and rings get dipped in trans fluid for assembly lube.
G |
