very perplexing problem
I need some massive help from a smart motor guy...
I have a high compression, 9.8 to 1, 3 liter with RSR cylinders and pistons, it is new with a 1000 miles on it. Webbers, MSD 6a, Pertronix pointless module.
Runs like a r%ped ape, usually.
Driving home from work, it sputters and stalls at highway speed. coast to the side.
It tries to start, but dies. Then it starts, very rough. I drive away to get off the highway sputtering and dieing. Runs fine, then rough, sputtering, loses power, and dies again.
Starts like a champ and drives away 100% normal. Fixed. Get back on the highway and after 3-4 minutes, and it starts all over again. I let it rest 5 minutes. Speak to an officer of the law for a while. I finally get it home.
Clear K&N gas filter is fine with gas in it.
???????. Being it seems to have an intermittent nature, sometimes it runs great, others it runs like poop, I am really not sure what it is.
1970 911 T
Old 03-02-2011, 04:07 PM
AutoBahned
RWebb's Avatar
if the gas is fine, then it has to be electrical...
Old 03-02-2011, 04:17 PM
pixxi's Avatar
Ignition coil - fails once it gets hot from running? (had this issue with 454 chev in boat, new coil fixed it)...
Old 03-02-2011, 04:21 PM
Forgot one thing, possibly very important. If the car idles for any length of time it will cough once in a while just once, like a miss. Never thought too much of it.
1970 911 T
Old 03-02-2011, 04:23 PM
wwest's Avatar
CDI ignition..?
Turn on all the electrical loads and see if it runs better.
Old 03-02-2011, 04:45 PM
Max Sluiter
Flieger's Avatar
How is the in-tank fuel filter screen? Rust can flake off the inside of the tank and get stuck in the screen and choke the engine after a while.
wwest's Avatar
Oh, ICE formation in the carburator...
Old 03-02-2011, 04:47 PM
tank was drained and cleaned out about 3 tank-fulls ago. Most mileage was put on the motor by the builder. I only have a hundred or so miles on it in this car.
Ignition is MSD, I believe it is CDI.
1970 911 T
Old 03-02-2011, 04:50 PM
it was about 62 degrees this afternoon, now this morning, it was 32, and it ran great.
1970 911 T
Old 03-02-2011, 04:51 PM
1QuickS's Avatar
Same thing happened to me, fuel tank strainer filled with tank debris starved the engine. Let it rest awhile and AOK.
Disconnect fuel supply at one of your carbs and let the fuel pump run and check fuel delivery. This could be a dynamic issue in that the debris may fall away when at rest but while driving it is drawn into the filter and plugs it. The tank filter is a fine wire mesh or strainer so this "dynamic" could occur which would make your problem seem to be intermittant.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 03-02-2011, 04:54 PM
Just a shot in the dark........but venting on your fuel cap? Take your cap off and see if it helps or if it dies again take it off and see how much pressure is built up. Probably not the problem but a cheap and easy check.
Old 03-02-2011, 04:56 PM
Wine User
warner53's Avatar
Pretty engine, she runs just like a woman. LOL
Old 03-02-2011, 05:39 PM
yeah, reminds me of both x wives.
I will give these a try. Any thoughts of the occasional miss at idle prior to this?
1970 911 T
Old 03-02-2011, 05:52 PM
fastfredracing's Avatar
You would not be the first guy in history to get a faulty msd box. Do you have another one you could borrow, and try out ? Looks like a pretty clean install, but could not hurt to check the power and ground connections for the MSD as well.
No left turn un stoned
Old 03-02-2011, 06:11 PM
ghamilton's Avatar
My first guess was electrical also.
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 03-02-2011, 06:32 PM
Next time it happens remove the fuel bowl drain plugs (catch the fuel don't burn down your car)
If there's no fuel you've found your problem if there's plenty of fuel it's probably ign
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 03-02-2011, 06:45 PM
nice.
great move.
1970 911 T
Old 03-02-2011, 06:46 PM
Thankx folks.
Pulled the gas tank out today cuz I found lots of black ***** in there. Looks like a PO had coated the tank with something and it is all flaking off and clogging the tank filter. I am going to find a radiator shop and let them do what they do best....I cannot believe this was not the root of the problem.
1970 911 T
Old 03-06-2011, 11:40 AM
Sorry i had forgotten the gratuitous picture of the offending tank
1970 911 T
Old 03-06-2011, 11:47 AM
Max Sluiter
Flieger's Avatar
Nice brace. Did you make it yourself?
Old 03-06-2011, 01:58 PM
