How high to get it out?
How high does the rear of a 911 have to be to get the engine out?
I have a stock 1985 Carrera. Thanks. |
abit off center
are you taking the bumper off?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
sudo apt-get purge 930
Measure from the top of the engine to the ground (A). Measure the distance from the bottom of the engine to the ground (B). Measure the lowest height of whatever you are using to drop the engine (C). A-B+C= Height needed.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I had planned to leave the bumper on. Is it easy to remove the bumper? Is it worth it to remove it?
abit off center
Its pretty easy to remove. If you don't I found you have to also raise the front of the car otherwise the car is at too steep an angle to get the engine out clean.
I've heard rear end jack height something like 36"... [rear bumper on]
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
I use an atv jack to lower the engine initially, which requires the car to be level on 4 jackstands.
After the engine is down, I lower the front end, which raises the rear bumper quite a bit. Use 6-ton jackstands, which are wide and have the required stability. It's suicide to use 2 ton stands, which won't go up high enough without being on blocks. Use a jack pad on the side of the car with blocks to get the car up high enough. I have video somewhere if you need it. |
The bumper comes off very easily and makes the job a lot easier.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
When the engine is down, the car is on jackstands, I like to use a 2X6 or 8 a couple feet long under the floor pan as far to the rear of the pan I can get. Using a floor jack, lift the chassis and its no problem getting high enough to clear the engine.
Bruce |
+1 This is how i do it. No need to remove the bumper.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
+2 easiest way.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
agree with rusnak and sjf911. remove the bumper, or at least the bumper guards. also, i used a cherry picker/engine lift attached to rear frame rails to initially lift the rear of the car high enough for engine installation. quick and easy.
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
Thread Tools | |
Rate This Thread | |
