rnln's Avatar
question on replacing brake bleeder valve.
Hi,
I was in the middle of replacing brake fluid and found that one of my front bleeder valve was stuck, and even bent (crooked) I think. Got new valves now but couldn't take off the old valve. I am thinking of blowing torch to it, but not sure if I should blow the fire directly to the valve, or the caliper body surrounding the valve?
Will seals in the caliper be melt/damaged?
Thanks.
Fat butt 911, 1987
Old 03-22-2011, 01:12 AM
Senior Advisor
James Brown's Avatar
Be carful they can snap off then your stuck on getting a new caliper. Heat might work just go back and forth a little at a time and it might come out.
08 Cayenne Turbo
Old 03-22-2011, 01:21 AM
rnln's Avatar
oh no, now you scared me.
Thanks James.
Fat butt 911, 1987
Old 03-22-2011, 01:26 AM
Northern Motorhead
wildcat077's Avatar
I usually use a torch to heat up the bleeders before i attempt to break them loose,it avoids stripping them and having to use vise grips afterwards ...
No damage will happen to the seals as you are only heating one small area !
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-22-2011, 03:06 AM
jsmithcds's Avatar
torch
I have used the wifes small kitchen torch that she uses for caramelizing sugar. It has a fine pointed flame that is perfect for small areas. Just make sure to get all the black brake dust off it before you put it back in the cupboard......
May i also recommend speed bleeders to anyone replacing these valves for any reason. Great little devices.
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 03-22-2011, 04:07 AM
rnln's Avatar
thanks.
Fat butt 911, 1987
Old 03-22-2011, 01:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey, I thought we were going to do this together?
Since your are replacing it, why not just get the vice grip for more torque to break it loose.
Like above said do a little at a time.
'85 Carrera Targa
PCA/POC
Old 03-22-2011, 05:07 PM
Northern, CA
Are You Sure About Heat?
I've always been told not to use heat on brake calipers for fear of damaging rubber parts like caliper seals. I guess if you're very careful you might risk it.
Have you tried soaking the bleeder valves with Kroil or penetrating oil for a few days before trying the wrench again?
1989 Carrera Coupe
Old 03-22-2011, 06:26 PM
rnln's Avatar
Draco,
I planned on replacing brake lines and bleeder valves first, then we can do the fluid while having fun.
I already tried the vice grip with no help. It only messed up the bleeder valve more. I already bought a set of longer sockets, hope it'll help.
Thanks J
big911fan,
Have not tried that. Will do. Thanks.
Fat butt 911, 1987
Old 03-23-2011, 02:20 AM
