how to install operable front quarter glass/window
I used search and could not find but someone installed operable front quarter glass or what ever the front window is called.
I do not want to spend to make A/C acceptable and would like to install an operable front glass (in front of my front door glass) Any help appreciated. |
I would also like to know what parts are required from what years of car.
AC is marginal without spending big coin and it's too noisey having the windows down. I think the little opening front quarters would be great. Anyone got info ? |
You need to source complete pre 71 coupe window frames, complete with vent wings.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
AutoBahned
Thanks Randy. Is that your car?
So I'm looking for parts only from the 71 year coupes? Or targas too? |
I believe, that only the '68 had the opening vent widows in the coupe. All targas have them, but they are incompatible with a coupe. If you have a coupe, you'll have to find a '68 door.
Just my 2 cents.... |
Drive X is correct 68 was the last year for opening wings on a coupe. My bad.
AutoBahned
yes it is Andy - I also think 1968 is the year
there is also some thing about brass vs. Al ones, but I don't recall the difference right now Early911S bbs knows all the details about what came when on which models... |
So I'd need all the door harware from a 68? Sounds easy to find!
The diabolicalist
My junk: 1988 3.2 Targa- Damn near option-less! Crawl with me into tomorrow or I'll drag you to your grave. I'm deep inside your children... they'll betray you in my name!! |
I case you don't already know what the differences are; coupe vs targa:
Coupe Wing Vent '65 thru '68: ![]() Targa Wing Vents (more squared at the top for targa roof): ![]() |
You can use frames from earlier years but they are made from chromed brass. They will fit but the finish will not match the rest of the windows. They are easier to find (more were made) but are much heavier (if that's a concern) than the aluminum frame. It's really your call. If you go "shopping" online, refer to the photo posted by Tidybuoy--that is a chrome/brass frame. You can easily identify it because of the long front leg extending down from the front of the vent window. Not only can you see where the chrome stops and the brass continues, but the length of the leg is a give away. Aluminum frames have a short front leg which extends only to about where the chrome plating in the photo stops. Keep this in mind when looking at small pictures that you come across in your search and you can quickly eliminate earlier frames.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 06-30-2012 at 07:07 AM.. |
Ossiblue is correct with the frame info. I had a 73T coupe years ago that I had installed the early chrome plated brass frames with the movable vent windows. The chrome was not in good shape but the frames were. We ended up lightly sandblasting them and all the rest of the AL mouldings on the car and painted them a satin black. Later 911's had that look anyhow. It looked great as the car was signal yellow. So that is an option if you cannot find good 68 frames.
I now have a 74 911 and did find a good set of 68 frames (not cheap) and are about to do the swap. The 74 does not have AC and I do remember from the 73 being able to open the vent windows was great. This time we will keep the polished AL look all around. I have not checked if the frames are even available new-would doubt it. The glass and the rubber gasket are however. Also the only difference I can see between the 68 frames and the later 69-on frames is the curved insert for the window (separate piece), the hole on the frame for the pivot and the support piece to lock the window closed (another separate piece). I suppose one could take a 69 and later frame and modify it (drill the pivot hole) and try to make or source the rest of the pieces. Might be doable. jjs3rd914 |
Targa guids
On the Targa parts, can I use my current guide or is that only for this setup?
I have a 71 that was C2'd in the 90's with SC doors that I'm bringing back to the 70's ![]()
HankP 1976S Targa BMW R100RT&RS&R75/5&6 Horizontally Apposed |
Thread Tools | |
Rate This Thread | |
