North Coast Cab's Avatar
930 911 Control Arm Interchangeability
Is ther any differnce between an '87 930 front control arm and an SC or Carrera arm?
TIA
1985.5 944 GTS
Old 04-22-2011, 10:52 AM
KTL KTL is offline
Schleprock
KTL's Avatar
They don't have the same part number. 930 starts with 930 and SC, Carrera start with 911. So there has to be some kind of difference to warrant having different part numbers.
Kevin L
'86 Carrera "Larry"
Old 04-22-2011, 10:57 AM
sudo apt-get purge 930
equality72521's Avatar
The 930 control arm has a spacer welded on for anti dive characteristics. Search my user name in the turbo section for info.
--clutch-monkey
Old 04-22-2011, 11:03 AM
Check out the pics here: I need detailed front A-arm mount pics
--clutch-monkey
Old 04-22-2011, 11:05 AM
This post shows both: Can't get front torsion bars out, cross post from turbo board
--clutch-monkey
Old 04-22-2011, 11:09 AM
Max Sluiter
Flieger's Avatar
I think the arms themselves are the same, but the mounts are definately different.
Less brakes, more gas!
euro911sc's Avatar
If you want to make a 911 arm into a turbo arm you just put a nice hardened spacer in there. If you buy the Elephant self centering kit they come with extra spacers to do just this.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-25-2011, 06:13 AM
