MSD Tach Option
Does anyone know if there is a certain year tach that works without modification with a MSD setup? I am putting carbs on my 3.2 with a 2.7 distributor with points and a MSD 6AL. I have been told to send my 73 tach to a place to have it adapted for the MSD which is fine but if there is a certain year stock tach that works that may be a less expensive route for me. Any ideas or do I have to get the tach adapted regardless of the year? Thanks for any input.
72 911 T Targa 3.2
01 Boxster S
Old 04-26-2011, 07:15 AM
Tom '74 911's Avatar
I can't help other than to say that I used an MSD for 4 or so years w/my '74 tach w/out any adapters or other mods to the tach itself. It worked fine as far as I could tell.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 04-26-2011, 07:18 AM
ASE Master Tech - 35 yrs
larrym's Avatar
my 1970 tach works fine with MSD 6A, I also do have the 8910 tach adaptor and 8680 timing controller
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 04-26-2011, 11:19 AM
75 tach with no adapter or mods here too.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-26-2011, 11:28 AM
My 80 works with no adapter.
I think it's a question of individual sensitivity. The MSD sends very weak pulses compared to the factory CD box. If your individual gauge is sensitive enough, it will work fine. Based on what I've seen, it's 50/50 that any given year/model will work or not without the adapter, but it seems to be 100% that it WILL work WITH the adapter.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-27-2011, 02:08 PM
Senior Advisor
James Brown's Avatar
81 no adapter
08 Cayenne Turbo
Old 04-27-2011, 02:29 PM
thanks for the replies. I wonder what the tach shops would do then to the tach that costs 160 bucks? Kind of makes me want to at least try my stock tach.
72 911 T Targa 3.2
01 Boxster S
Old 04-27-2011, 05:20 PM
schumicat's Avatar
according to the 101 projects book, some tachs of all years will work fine w/o the adapter, and some need the adapter and no one knows why. you may as well try it w/o the adapter first.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-27-2011, 05:52 PM
2.7 dist
If you are using a 2.7 dist as it came out of a 2.7 the gear on the dist. is going to give you way to much gear backlash if you are using the 3.2 drive gear on the crank, from 84 on it is Clockwise rotation but they need the "large" CW dist gear, if you have the 3.2 dist swap the gears.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 04-27-2011, 05:59 PM
Originally Posted by james brown View Post
81 no adapter
+1
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 04-27-2011, 08:53 PM
