Turn signal gremlin
Hi all:
In my 79 SC, right side turn signal blinking rapidy. Mechanic replaced relay; fixed that problem. HOWEVER, now, whether L or R turn signal activated, BOTH speedo turn signal lights flash simultaneously.
I have searched the posts but didn't find any similar problem. Anyone have any idea of what is causing this? If it's an easy fix, I'll do it myself as opposed to having to lose the car for a day and having to find a ride to and from the mechanic.
FYI, I pulled the speedo to install LED replacement gauge lights and everything seemed to be connected back there.
Thanks for all your help!!!
Steve G
Old 04-30-2011, 09:04 AM
Steve, first check to make sure your turn signals and brake lights are working as they should- flashing properly, brightness is correct etc.. I'll bet you'll find the source of the problem..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 04-30-2011, 09:51 AM
dshepp806's Avatar
look for the flaky ground!!!!!!!!!!!! (Or, bad light bulb).
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-30-2011, 11:00 AM
Neel, thanks, I checked all the turn signal bulbs and they and the brake lights all work fine. Ideas?
Old 04-30-2011, 03:44 PM
Mine does that too, maybe someone has the answer.
Old 04-30-2011, 05:26 PM
Ok, now check everything again with the running lights on..
84 Mustang Turbo GT
Old 04-30-2011, 05:39 PM
Check the bulb wattage. You have to draw the correct amount of current. Check your cars schematic and make sure they are all correct.
I suspect you have some low wattage bulbs somewhere.
Old 04-30-2011, 05:52 PM
Very true.. This should show up in a visual inspection.. I've also seen double filament bulbs fail by one filament 'welding' itself to the other filament.. This makes all kinds of wierd things happen..
84 Mustang Turbo GT
Old 04-30-2011, 06:00 PM
dyusem's Avatar
I'm not a wrench but the last time my '80 SC was in the shop the turn signal relay went dead. My mechanic had a replacement relay in stock but he wasn't sure that it was correct.
The replacement fixed the turn signal issue but now under certain circumstances both lights on the speedo will flash simultaneously so I suspect the relay may have something to do with it as all light bulbs were proactively changed last fall.
Could use of the incorrect relay cause this issue???
Old 05-01-2011, 07:58 AM
of course an incorrect relay will cause weird stuff to happen.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-01-2011, 08:28 AM
