Turn signal gremlin
Hi all:
In my 79 SC, right side turn signal blinking rapidy. Mechanic replaced relay; fixed that problem. HOWEVER, now, whether L or R turn signal activated, BOTH speedo turn signal lights flash simultaneously. I have searched the posts but didn't find any similar problem. Anyone have any idea of what is causing this? If it's an easy fix, I'll do it myself as opposed to having to lose the car for a day and having to find a ride to and from the mechanic. FYI, I pulled the speedo to install LED replacement gauge lights and everything seemed to be connected back there. Thanks for all your help!!! Steve G |
Steve, first check to make sure your turn signals and brake lights are working as they should- flashing properly, brightness is correct etc.. I'll bet you'll find the source of the problem..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
look for the flaky ground!!!!!!!!!!!! (Or, bad light bulb).
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Neel, thanks, I checked all the turn signal bulbs and they and the brake lights all work fine. Ideas?
Mine does that too, maybe someone has the answer.
Ok, now check everything again with the running lights on..
Check the bulb wattage. You have to draw the correct amount of current. Check your cars schematic and make sure they are all correct.
I suspect you have some low wattage bulbs somewhere. |
Very true.. This should show up in a visual inspection.. I've also seen double filament bulbs fail by one filament 'welding' itself to the other filament.. This makes all kinds of wierd things happen..
I'm not a wrench but the last time my '80 SC was in the shop the turn signal relay went dead. My mechanic had a replacement relay in stock but he wasn't sure that it was correct.
The replacement fixed the turn signal issue but now under certain circumstances both lights on the speedo will flash simultaneously so I suspect the relay may have something to do with it as all light bulbs were proactively changed last fall. Could use of the incorrect relay cause this issue??? |
of course an incorrect relay will cause weird stuff to happen.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
