Tim L's Avatar
Before you go too crazy trouble shooting that noise just remove your drain plug on the engine I think you'll have your answer.
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 05-17-2011, 05:34 AM
Super Moderator
cstreit's Avatar
I hope that piece of metal isn't what it looks like.
It definitely looks like rod bearing. The sound sounds like rod knock.
Take off your sump plate and let us know what you find before you go any further.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-17-2011, 07:34 AM
Ok, when I get home this PM I'll be taking off the sump plate and oil drain plugs.
I'll let you know what I find.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-17-2011, 07:39 AM
Super Moderator
cstreit's Avatar
Best of luck!
Subscribing to the thread so I'll watch for your replies...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-17-2011, 07:51 AM
Super Moderator
cstreit's Avatar
Originally Posted by maxhofer View Post
But, can a piece of rod bearing get into the left chain case?
That stuff gets EVERYWHERE. IN fact I think that's often the worst part of a failed bearing. it's not the rebuild, replacing the rod, checking the crank or any of that jazz. It's trying to get the 34,000,000,000 pieces of rod bearing material out of every crack, crevice, oil line, journal, galley, pump, and cooler in the system. BTDT, hated it.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-17-2011, 08:45 AM
Best of luck!
Thanks cstreit, I think I'll need a lot of luck in this one!!!
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-17-2011, 08:58 AM
j911brick's Avatar
Don't forget to open up the oil filter.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 05-17-2011, 12:31 PM
TibetanT's Avatar
No sump plate on a 1985 Carrera, right?
Put a thin rag, old white one, inside the tub/container you drain your oil into. That way you can catch the bits and pieces of metal to evaluate the overall damage done, if any.
Let's hope there isn't any, but then again that "noice" doesn't sound promising.
From the pictures, it appears that the left idler arm, driver's side chain box, is hitting the top of the chain box. That may be the knocking noice and proof that the chain tensioner isn't getting fed much oil pressure. Also, I noticed the left chain box, driver's side, has a dark colored hue within the box itself where the right-side chain box, passenger's side, is cleaner. Shows signs that there is oil getting circulated there, but not on the other side.
Just an observation.
Good luck with this!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-17-2011, 05:40 PM
j911brick's Avatar
Yes it does.
james
Old 05-17-2011, 06:16 PM
TibetanT's Avatar
Originally Posted by j911brick View Post
Yes it does.
So this guy's car has a 3.0L engine in it?
Ed Paquette
1983 911SC
1987 944S
Old 05-17-2011, 07:14 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Sorry, but you have a rod bearing failure, and here's what it will look like when you crack the case open:
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-17-2011, 07:27 PM
j911brick's Avatar
All 911s have sump plates. What they did away with was the drain plug on the sump plate so you have to remove the whole sump plate in those cases.
james
Old 05-17-2011, 11:04 PM
James, are you sure about the sum plate in my car?
My oil drain plug is the same as the one shown in this picture (from the Bentley manual):
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-18-2011, 07:39 AM
Tim L's Avatar
yes, no sump plate for you.
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 05-18-2011, 07:45 AM
Wow!!! those pieces of metal in Zoa's first picture look like mine....I'm hoping for a miracle!!!
I couldn't work on the car last night, but will get on it today for sure.
Il take the oil out and filter it to see what I find. Also will open the filter as suggested by James.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-18-2011, 07:48 AM
Super Moderator
cstreit's Avatar
Yep, sorry Max I didn't look at your car's year. Still, then drain the oil through a screen, and cut open your oil filter. I'm still hopeful that this is not it, but pretty sure you're going to find a mess. BTDT
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-18-2011, 07:53 AM
Tim L's Avatar
The bearing parts are magnetic and stick to the drain plug. You'll know one way or another when you pull the plug.
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 05-18-2011, 08:01 AM
j911brick's Avatar
Sorry. I was confused and therefore incorrect. Sorry if it caused any confusion.
james
Old 05-18-2011, 09:35 AM
Update
Ok, I pulled the oil drain plug, filtered the oil that came out, removed the oil filter and opened it.
Here are the pictures:
Drain plug and bits of metal that were in the oil:
Oil filter, the shiny spots are small pieces of metal:
Looks like rod bearing failure, doesn't it?
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-18-2011, 06:45 PM
Almost Banned Once
sc_rufctr's Avatar
Ok, I pulled the oil drain plug... Looks like rod bearing failure, doesn't it?
Other will chime in but based on what you have found I would be stripping down that engine.
What's actually failed??? As others have suggested most likely a Rod Bearing but until you get her apart you won't know how bad it.
Hopefully not too much damage has been done internally.
Have you got some basic tools, jack and help if needed? Good luck with everything.
- Peter
Old 05-18-2011, 07:17 PM
