Originally Posted by DRACO A5OG View Post
What kind of oil are you using or used?
Draco, I'm using Liqui-Moly 20W-50 non-synthetic.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-09-2011, 08:04 AM
re. mechanics stethoscope, I've read and tried using a wooden dowel. For some reason(s) it seemed to filter out the unwanted noise. Just put one end on the engine spot of interest and hold it against your ear.
Old 05-09-2011, 08:14 AM
I'm picking one up this p.m. Due to mother's day I couldn't work on the car during the weekend, but i'll jump on it today.
Tazzieman's noise sounds very much like mine.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-09-2011, 08:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The reason I asked, I had the "Rumbling/Rattling Metal Trash Can" noise 2 years ago.
Drove on the freeway at moderate speed enjoying a drive to the beach then all of a sudden, the rumble noise occurred.
Limped home and took both fans off, used a stehtescope and verified the noise was coming from the driverside chain cover. I was ready to take her in the next day but the noise disappeared. Weird.
About a year ago, it came back for a day then went away again. Strange.
2 years ago, I started to use different brand of oil (not liqui-moly) but Mobil 1 synth to Dino/Synth mix. I thought to me is was to too much of a coincedense. Now I use straight Dino, have not heard the Rumble of the Trash Can yet. If it does, then I guess it will be time to tear her apart to take a peak inside.
'85 Carrera Targa
PCA/POC
Old 05-09-2011, 03:00 PM
j911brick's Avatar
if its not the chain tensioner I would guess intermediate shaft bearings.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 05-10-2011, 01:22 AM
UPDATE:
Ok, here's what I've found so far. I went for the chain tensioners first.
This is how the passenger side cover looked like before opening:
As you can see cover was very dirty and with signs of oil dripping around the bottom.
This is how the driver's side cover looked before opening:
As you can see, the driver's side cover was very clean and with very little oil dripping from the bottom.
When I disconnected the oil tube from the passenger/right side a lot of oil came out. BUT when I disconnected the tube from the driver/left side very little oil came out.
When I opened the passenger cover a lot of oil dripped from inside also. BUT AGAIN, when I opened the driver's side very little oil came out from inside the case.
Can it be that I was getting less oil into the left side than into the right side?
A look at the inside of the cases:
Passenger/Right side Case:
Driver's/Left side Case:
On the tensioners:
I pressed on the passenger/right side chain and the tensioner's piston did not move at all. I also tried to press the piston itself, but it was hard as a rock.
BUT, when I pressed the driver's/left side chain the piston compressed inmediatelly. Here is a couple of videos of the action:
I checked both of the oil tubes going into the cases/tensioners and they both were unclogged.
Can it be that my driver's/left tensioner wasn't getting enough oil pressure? Or is it definetely failed?
The difference in the amount of oil that came out from both of the cases makes me wonder if the problem is oil circulation.
Another find!!!:
When I removed the driver's/left cover I found a small metal piece that looks a piece of wrinkled aluminum foil (a bit thicker).
It was sticking to the inside of the cover:
Any idea of where this piece of metal could have come from????
Again, any ideas, guesses, comments will be greatly appreciated!!!
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 11:04 AM
j911brick's Avatar
I might consider putting it back together and testing the oil pressure on each side. I would also check the left cam for starvation. Given that hunk of metal, the left port may be clogged. But that is the least of your problems. That hunk of metal looks like part of a bearing shell. Pull the IMS cover off and see if you can detect any movement with the IMS by tugging on the chains. I'm still leaning towards defective IMS bearings.
james
Old 05-16-2011, 11:56 AM
Thanks James, I'll pull the IMS cover off and see what I find. Will post results.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 12:48 PM
Tim L's Avatar
I would drain the oil and see if you don't have a lot of bearing material on the magnetic plug. it could be a failed rod bearing.
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 05-16-2011, 01:27 PM
Good idea, will do that too.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 01:30 PM
Question for j911brick:
James, I'm working with the engine on the car. To get to the intermediate shaft cover I guess I'll have to go on to a partial engine drop as the cover is behind the engine support bracket.
Am I right?
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 04:29 PM
Right you have to remove the engine mount.
Look on top of the tensioners in the recessed hole next to the piston rod there should be a raised cap with a open hole at top, are they still there?
Old 05-16-2011, 06:01 PM
4sd911, here are pictures of the tensioners, am I missing the caps?:
Driver's/Left Right side tensioner:
Passenger/Right side tensioner:
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 06:30 PM
I hate to say it but that's a rod bearing. Failed rods have a very particular noise and that's it
The piece of metal is a piece of bearing
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 05-16-2011, 07:12 PM
But, can a piece of rod bearing get into the left chain case?
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 07:56 PM
The caps are both in place on the tensioners.
Old 05-16-2011, 08:16 PM
Have you looked behind the valve covers yet?
Old 05-16-2011, 08:23 PM
Not yet, will do it tomorrow.
Guess I'll be looking for a broken valve spring, loose rocker or broken rocker shaft.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-16-2011, 08:43 PM
Yes, also look at the cam lobes if the spray bar is clogged a rocker could dig into it. The bearing failure is a possibility but is easier to inspect behind the covers first.
Metal pieces floating in the oil on the bottom of the case can make there way to the chains and end up in the chain boxes.
Old 05-16-2011, 11:23 PM
j911brick's Avatar
You don't exactly have to do a partial engine drop. You could just support the engine from the bottom and remove the muffler and engine mount. Probably easier to work with if you just drop the motor though. Either way there is a good chance the motor has to come out so prepare for that. Your probably not going to learn much under the valve cover That kind of material won't come from there. The poster that suggested rod bearings may me right. IMS bearings, which are about the thing as rod bearings, will usually have copper in them. SOunds more like a IMS bearing than a rod bearing to me. IMS bearing failure sounds like a chain tensioner failure; Rod bearing usually sounds slower and heavier. As previously suggested, best bet at the moment will be to pull the sump plate and open up the oil filter. Any flakes and you need a new motor. Sorry.
james
Old 05-17-2011, 01:02 AM
