Wideband O2 sensor cable routing?
Before I start drilling, does anyone know if there is a convenient place to run the cable from a wideband O2 sensor into the cabin on my 1986 911?
Thanks. |
RETIRED
There might be enough room thru the DME cabling port on the drivers side......I used it for the head temp wiring.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
sudo apt-get purge 930
Do you use your A/C? I removed mine and ran flexible gray electrical conduit in place of the A/C lines on the driver side. There is a hole in the front driver side "trunk" near the washer bottle to enter into the trunk and can then be routed to the back side of the dash.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
On my 1973 I ran it through the tunnel. I used and existing grommet for a harness. but I am sure your car is different. What kind of AFR setup? How many wires.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Ran mine with the main harness to the engine then routed the wire under the carpet at the base of the tunnel to the guage that is in place of the ashtray.
1986 3.2 Carrera |
Thanks guys. I followed the main harness through the DME grommet behind the drivers seat. Taking out the rear seat stuff and going through the firewall behind the air filter may have been less work though.
Putting in the sensor cable for an Innovate LM-2. The plug is fairly big. Mike |
