LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Member 911 Anonymous
DRACO A5OG's Avatar
Smile
Originally Posted by nineball View Post
i can't tell you how many of these "my plug won't fit" threads i have read on this board but i can tell you i have never had a problem with any of my charger plugs (garmin, apple) falling out in my '83. i know i still have the factory setup or the lighter would not fit in there. i'll just leave it at a miracle mystery and go on with life.
Because you are a Nineball not a 8ball like the rest of us poor mugs
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 10:15 AM
DRACO A5OG's Avatar
Wink O-rings! I tell yeah O-rings
Originally Posted by NO LIFT View Post
Please ask the good Dr. to come up with a similar solution to loose rear light bulbs...
Easy, O-Rings, one or two and call me in the morning :P
The O-ring/s will eliminate all slop and make a nice tight seal from moisture intrusion.
Just slip it on your bulb and then slip it in the socket, it will be tight, if the O-ring migrates up, use a small flat head screw driver to push it back on to the edge of the socket. THAT's IT!
Jim
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 10:20 AM
rnln's Avatar
any replacement socket would fit or only certain size?
I made my own "tool" to fit my GPS everytime I use it in my 911, free, but I will need this because my "tool" will fall off when you put the plug off the socket. It is simply a folded small piece of paper
Fat butt 911, 1987
Old 03-31-2012, 03:16 AM
DRACO A5OG's Avatar
Well, any accept OEM type, it will not fit in between the OEM cig lighter anyways due it being the same diameter.
Basically you need a slight thinner diameter replacement socket to slide snuggly into the OEM socket, but not too loose or it will come out with your device.
No, it will not work with the OEM lighter, if you smoke you need the new modern kit with lighter.
'85 Carrera Targa
PCA/POC
Old 03-31-2012, 09:51 AM
muck-raker
kidrock's Avatar
Just wanted to revive this thread and give a big shout out to Jim for such a cheap, simple and useful upgrade.
I was at my local FLAPS to dump some used oil after my regularly-scheduled change. Remembering that I had recently picked up a $15 voltmeter that has been a little wobbly in my stock cigar lighter, I decided to give Jim's solution a go.
Here's the result:
OK, not the greatest image in the world, but you get the picture.
So, $15 for the voltmeter, $4 for the lighter sleeve, and about 10 minutes of labor, and I have a great little voltmeter installation that can be installed and removed in a snap, and all my chargers and converters now fit like a glove.
Big shout out....Thanks again, Jim. One of these days during one of my surfing trips to SD, I promise to take the short trip up to buy you a beer or 6.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-20-2012, 05:35 PM
DRACO A5OG's Avatar
Nice Brother
Hey just noticed your extinguisher, I guess no fear of stealing from you, huh?
I have mine under my passenger seat bottom rear, fits perfect
Heck I will even come down and visit my TKD Studio and my Master while I am down their
'85 Carrera Targa
PCA/POC
Old 04-20-2012, 06:02 PM
muck-raker
kidrock's Avatar
Originally Posted by DRACO A5OG View Post
Nice Brother
haha, protected by Heckler & Koch .40
Maybe we should meet over at Mirage and hook up Jae while we're at it
STONE
Old 04-20-2012, 07:15 PM
Hey there - sorry to bump an old thread. I gave the good Dr's fix a try and didn't have success. I couldn't get an electrical connection with the insert in place, but when I removed it I could. I purchased the exact lighter replacement well as pictured, and cut off the bottom 3/8" as suggested. Any ideas why it isn't working?
Thanks!
Dan
'86 Carrera coupe
Old 12-29-2012, 07:51 PM
DRACO A5OG's Avatar
Hey Dan,
Do you have a DVM ( Digital Volt Meter )? Let's check to insure you have a good 12v and ground.
I would guess maybe it needs to be shaved down a bit more so the 12v source is not making contact with the new sleeve.
You see the idea is the center contact is your 12v and the side wall is you ground. once you place you device into the socket, it will close the circuit. If the sleeve is too long, it may cause a closed circuit and not allow your device to close. Hope that makes sense.
Jim
'85 Carrera Targa
PCA/POC
Old 12-29-2012, 07:56 PM
Thanks for the advice, Jim. I'll shave it down a bit more tomorrow and see if that works.
Cheers,
Dan
'86 Carrera coupe
Old 12-29-2012, 10:41 PM
Recreational Mechanic
Nickshu's Avatar
Sweet...doing that today!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-30-2012, 06:04 AM
RETIRED
Joe Bob's Avatar
Oi....maybe I could send this thread to my ex. Her 'well' needs work as well.....bada bump....
2012 ML350 3.0 Turbo Diesel
Old 12-30-2012, 12:12 PM
DRACO A5OG's Avatar
Lol
'85 Carrera Targa
PCA/POC
Old 12-30-2012, 05:05 PM
Success! I whittled the well down a bit more, but that didn't work. So, how I solved the problem was by switching to a slightly longer charger. The one I had been using was a bit, uh, underendowed, shall we say, and I don't think the tip could make contact once I put the sleeve in. Once again, size does matter. ;-)
Give the good Dr. my thanks for his fix, and thanks again, Jim, for the advice!
Dan
'86 Carrera coupe
Old 12-30-2012, 08:30 PM
DRACO A5OG's Avatar
Congrats, will let the doctor know day after tomorrow on NYD drive
'85 Carrera Targa
PCA/POC
Old 12-30-2012, 08:32 PM
LOVEHZ's Avatar
Brilliant. Tried tape, plastic spacers etc. Nothing really worked until this. Thanks.
Old 04-12-2014, 12:36 PM
bugstrider's Avatar
Courtesy thread bump to accommodate the "Install Voltmeter Now" thread. Great mod that I will be doing this afternoon..
Thanks again for the great idea Jim.
Cheers
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 02-18-2016, 10:51 AM
DRACO A5OG's Avatar
woohoo! an oldie but a goodie
'85 Carrera Targa
PCA/POC
Old 02-18-2016, 12:40 PM
Is there or where is the tread re. how to get the socket out of the dash? I have the blower/etc. out and the stock socket is loose what is the trick? Thanks.
Sold: 1989 3.2 coupe, 112k miles
Old 05-10-2017, 01:31 PM
DRACO A5OG's Avatar
Yes, from the FRUNK, you have to remove all fresh air plumbing to get behind the dash, sorry to write.
'85 Carrera Targa
PCA/POC
Old 05-10-2017, 01:36 PM
