broken drop link
I was installing the cat. to take it in for smog and noticed the drop link broke at the bottom. How hard to replace it?
Thanks Barclay _______________ 1981SC Coupe |
Member 911 Anonymous
Easy, two bolts, 19MM, 61 ft lbs, I would replace in paiirs
Leave the car on the ground, raising will pre-load them or raide the car and use a second jack to raise the trailing arm to the link, much more difficult and dangerous.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-06-2011 at 05:01 PM.. |
Can I get to them with car on the ground?
Sounds like some ramps would do the trick?
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Yes, on the ground. If you are too large then ramps would help to gain better access but not really needed in my case.
Depending if your car is stock or upgraded to thicker sways, you may need a Long Philips to manuveur the drop link and maybe a wood clamps to keep the link in place. To break the bolts/nuts loose use a cheater bar.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-06-2011 at 06:33 PM.. |
