|  | LinkBack | Thread Tools | Rate Thread |
| Registered Join Date: Jun 2003 Location: Camarillo, Ca.
			I offer a rebuild service for distributors as well.
				__________________ Aaron.  F.S. 1965 Solex engine w carbs/cleaner Burnham Performance https://www.instagram.com/burnhamperformance/ | ||
|  06-08-2011, 09:05 AM |
| Member 911 Anonymous | Quote:
 This is totally, anecdotal and only my personal experience but when I tested my dizzy after my attempts of a DIY rebuild, she did run quiet and normal until I took her up to 80 MPH, then the buzzing started however she did not skip or struggle in anyway. But still better safe then sorry, I also purchased a known good one for $150. I tested about four of them in a bin by spinning them and looking for smoothness with a bit of resistance. I learned if it spins too FREELY without any resistance, that is signs of a soon to be Bad Dizzy. Wow, his prices have not changed in 3 years  that is OLD SCHOOL FOR Yeah. Jim
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  06-08-2011, 09:48 AM |
Do you also custom make the internal bushings for the 3.2 Distributors?   Jim
|  06-08-2011, 09:52 AM |
			I do, as well as the internal seal if necessary. It is rare that bushings are out of spec if proper lubrication is maintained. The failure process is this; 1. lack of oil to the upper fiber shim quickly causes it's failure. Excessive endplay is the warning sign that a service is necessary but there is a good chance that the bushings are still within spec. 2. If the distributor is left in this state the upper bearing rate of failure is quite rapid. I normally see this failure on 3.0liter SC distributors and all have had evidence of water damage which I assume is from washing the engine but could be contributedto other events.
|  06-08-2011, 10:18 AM |
 Barry H, stated those shims are NLA ( he called it Vycon/Vyton or something like that ). Please forgive me but How does one oil it? In the Car or Remove Lube and Replace? May I also ask how you feel about the position of the sprocket, there is only two ways it can go on the end of the shaft. 0 degrees 180 degrees from initial removal, No?
|  06-08-2011, 10:26 AM |
			Other than the 356/912 distributors there is no alignment problem. As far as lubing, I would do it out of the car and figure out a way to get oil to the upper shim.
|  06-08-2011, 10:41 AM |
 Maybe an oil bath then drip dry wipe access off  . I do not want dismantle ever again, I will leave it to your shop  Thank you again sir!
|  06-08-2011, 10:52 AM |
| Registered Join Date: Oct 2004
				 | Quote:
 I think fastening that little gear is critical. If it falls off, you might be looking for a new block. | ||
|  06-08-2011, 04:23 PM |
Agreed, I am a bit concerned by roll pins walking out.
|  06-08-2011, 05:04 PM |
			Great another reason not to use my spare
|  06-08-2011, 05:15 PM |
| Registered |
			Have you ever seen a properly installed roll pin walk out on one of these?  I've got a dizzy that the main shaft and gear were machined out to 3/16" and a double roll pin was installed.  I've been running this with no issue thus far.
|  06-08-2011, 05:37 PM |
			McMaster-Carr does have the steel TAPER PINs in Metric sizes as well.
|  06-08-2011, 05:40 PM |
| Registered |
			I'm sorry, but you are way off base here.   The factory pin is NOT what your calling a TAPERED pin which is seen in McMaster Carr.  The factory pin is a 4mm straight bodied pin with one-(1) end already mushroomed for the 4.5mm hole in the hardened steel gear.
|  06-08-2011, 10:53 PM |
Honestly no. To be fair, there are plenty of other distributors that utilize rollpins. Bosch however was not one of them. Personally I would not want to be the guy who installed one for a customer that walked out.
|  06-09-2011, 09:05 AM |
  Do you have a website?
|  06-09-2011, 12:57 PM |
			Sorry, no website yet...it's on the to do list! Give me a call if you have any questions.
|  06-09-2011, 01:55 PM |
			Roger That, maybe I will stop by when I'm up there showing properties   and bring my back up dizzy.
|  06-09-2011, 02:06 PM |
			Let me know, We had the Rothmans 962C at the shop a couple of weeks ago...maybe you'll get lucky and time your visit right.
|  06-09-2011, 04:42 PM |
