Optimoly HT equivalent ?
I am replacing my clutch and the sachs kit I bought had a small packet of what look like lube in the kit. I assume it is the shaft antiseize compound refered to as Optimoly HT in the Bentley manual .
At any rate I lost the packet ane need a local replacement to get my tranny back in this weekend.
I was going to use the permatex copper antiseize ( sparingly) as a substitute . Does anyone know if I would be making a big mistake to use this product ?? Is it thick enough to stay on the shaft ?
Where I live , the Optimoly HT is probably at least week or two away and want to get my car back together asap.
Old 06-10-2011, 06:10 PM
304065's Avatar
Optimoly HT is silver antiseize, very similar properties
I use Lubro Moly copper antiseize on everything
the Permatex is probably just fine
But if you must source a local version, try and find some silver antiseize.
Optimoly HT is made by Castrol, you can download their datasheet to compare it to whatever you find.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-10-2011, 06:50 PM
the little packet contains high temperature grease. You can get a tube of equivalent grease from another vendor who also has a forum and sells racing parts in souther Calif . It has to be shipped ground, so it takes forever to arrive.
Old 06-10-2011, 07:35 PM
Diss Member
Quicksilver's Avatar
I use Bosch distributor grease instead of the Optimoly HT. You should be able to find it at a VW shop.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-12-2011, 02:59 AM
Before seeing the note about the bosch grease I went ahead and put some permatex copper antiseize on the splines.did I make a major mistake?
I can dissassemble if necessary.
Old 06-12-2011, 07:46 AM
Bill Verburg's Avatar
Optimoly HT is a copper based high temp lube
Optimoly HT
Bill Verburg
Old 06-12-2011, 08:03 AM
Permatex Copper Anti-Seize is an equivalent product to OptimolyHT.
Bill Verburg
Old 06-12-2011, 08:04 AM
Thanks bill
Old 06-12-2011, 11:37 AM
Well done!!!! You did just fine.
Bosch distributor grease is not the correct product for this application.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-12-2011, 11:42 AM
Recreational User
porschenut's Avatar
The factory manuals also call for Optimoly TA in some applications. Does Permatex have an equivalent for that one too?
Old 06-17-2011, 10:53 AM
I wonder if you can just use copper antiseize everywhere they call for silver antiseize?
can't afford DSG
Old 06-17-2011, 01:49 PM
Still here
pmax's Avatar
Just to be clear, this is equivalent to OptimolyHT for the transmission splines, correct ?
Old 04-01-2018, 11:28 AM
Optimoly is now called: Castrol Molub-Alloy paste HT
Porsche # 000-043-004-OEM
Copper colored paste
Purchased thru Pelican
Always take the high road, it's far less crowded - Charlie Munger
Old 05-31-2019, 09:26 PM
When I bought my clutch parts from Pelican for my 88 911, a bought a tube of High Performance Grease made by Sachs based on my interaction with the PP Porsche specialist. Is this not the correct grease for the splines and also the clutch fork bearings?
Old 04-22-2020, 09:30 AM
Since nobody answered my previous question so far, I am posting a picture of what I received with my Pelican Parts clutch order. Would someone please tell me if this not correct for my 88 911 G50 and why?
Old 04-28-2020, 02:19 PM
kevingross's Avatar
I dunno how important it is, but Optimol HT is a little different from other anti-seizes I've used in that it appears to have a higher metal to lubricant mix. It really is a paste. I can't tell you whether that is significant in this context. I use it where I really want to be sure that a bit more metal flake stays in place. But that's just me. (My go-to anti-seize is Wurth CU800.) Cheers,
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 04-28-2020, 03:08 PM
So.
Nickel
Silver
Copper
Anti seize.
If cost is not a factor, it seems nickel can be used everywhere the others can at least on cars.
Is that accurate?
If what i read on manufacture websites is right or interpreted by me correctly... seems right?
Old 04-28-2020, 03:09 PM
donbecker1234's Avatar
AFAIK the nickel anti-seize is the high temp, used for exhaust.
Old 04-28-2020, 03:13 PM
The High Performance Grease made by Sachs is the correct grease for the clutch splines.
TSBs 8805 Lubrication of Clutch Parts and 8902 Modified Clutch Release Lever Shaft Bearings (for G50) call for the release lever and the contact points between the release bearing and release lever use Olista Longtime 3EP grease 000-043-024-00. This grease has been superseded to Porsche Extreme Pressure Grease 000-043-305-73.
Note that Technical Bulletin 3 911 Clutch Release Bearing for Carrera 1987-89 indicates that the guide tube and sliding surface of the release bearing should not be lubricated.
Edit
8902 Modified Clutch Release Lever Shaft Bearings (for G50) also has the release shaft bearings and the shaft cap/cover filled with 3EP grease.
Old 04-28-2020, 10:44 PM
Harold, thanks for the response.
Old 05-04-2020, 12:33 PM
