Born to Lose, Live to Win
ramonesfreak's Avatar
rust question
found what looks like a small amount of rust at the edge of the right front fender where it meets the trim piece near the accordion.
is this is a common spot and what should i expect. should i deal with this somehow asap and how? i dont have the $ for professional help so i would have to tackle it myself i guess...
looks like a good spot (being at the edge of the metal) to have a rust issue as opposed to it being somewhere in the middle of the body
Old 06-19-2011, 02:11 PM
j911brick's Avatar
Looks like rust started because of a previous repair. If you don't have talent and resources for painting then you might want to leave it alone. Your going to gave to clean the area at least 1/4" up from the seal and at le3ast get a good quality primer/sealer on it. You can clean it with sanding but sand blasting would be much better and last longer.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 06-19-2011, 02:32 PM
