Marlon Targa 86's Avatar
Electric problem: need help.
Car: 1986 Targa
Symptoms:
1. right side front & rear (passenger side) taillight/parking (the yellow light on the bumper) lights don't work
2. right side front (passenger side) turn signal doesn't work
3. when I use the right side (passenger side) turn signal, the "clicking" is twice as fast as when I use the left side blinker
Fuses are fine, light bulbs are fine, brake lights work and the reverse light works as well.
Any clues?
Marlon
1986 Targa 50K miles - Billstein Sports - Elephant 3 Point Strut Brace - Seine Shifter- Chin Spoiler - Turbo Tail
Old 06-25-2011, 01:24 PM
Spin the fuses in the holder as they build up insulation between metals.
Bruce
Old 06-25-2011, 01:46 PM
Bruce
Did that, too. No avail.
Old 06-25-2011, 01:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Common ground point?
#3 is usualy happend when a light bulb is burn (either half or twice the speed).
Who Will Live... Will See
Old 06-25-2011, 01:58 PM
Check the wattage of the bulbs vs the spec. Low wattage bulbs won't work.
Old 06-25-2011, 02:03 PM
dshepp806's Avatar
or, the wrong bulb.....make sure those grounds are good-2-go.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-25-2011, 02:53 PM
JJ 911SC's Avatar
Marlon
Did these 3 observations (actualy only 2 as 2 & 3 are the same problem) happened at the same time?
The worse thing would be to chase 2 problems; 1 & 2/3, at the same time.
2 & 3 are related and its probably "right side front (passenger side) turn signal" light bulb burned. Put a new one in no matter what it look like. If you don't have a new one, swap the two front one around and see if the symptoms stay to the right or switch to the left side.
When it comes to electrical, one could chase its tale by doing to many steps at the same time.
Do not rely on your memory, write down what you do and what the result are and post the results.
Old 06-25-2011, 04:15 PM
So, I measured the voltage at the fuse #19 for the passenger side parking lights and I get nothing... zero volts. (Fuse #18 for the drivers side gives me 12 volts.). What does THAT mean?
Also: problems #2 & #3 are solved. Cleaned the fitting and the indicator light is now working.
Old 06-26-2011, 03:46 PM
JJ 911SC's Avatar
As supected 2 & 3 were one of the same. Good
Back to # 19, both side of the fuse (from ground)?
Old 06-26-2011, 04:03 PM
You must have a supply problem to the fuse. Maybe the wiring in the back is damaged?
Old 06-26-2011, 04:51 PM
In the back of the dashboard or in the back of the car?
Old 06-26-2011, 05:21 PM
I'm not sure how fuse #19 is fed, but it might be on the back of the fuse panel that something is wrong.
Old 06-26-2011, 06:13 PM
How about this: I connect the working fuse #18 feed (driver side parking lights) to the #19 fuse and see what happens?
Marlon
Old 06-26-2011, 06:59 PM
