Ole Skool - wouldn't have it any other way |
I just installed the front set of RSR bushings on my car. One side went on fine after using the spherical washers but the other side... I can't get to move freely.
In my case, the driver's side moves freely but the passenger side does not. It takes a pound or two (less than 5 for sure) to get it to move. I realize that with the forces on the suspension this may be negligible, but while I'm here, I am trying to get it just right. This is for racing, no street use. When I hold the passenger side up to the chassis by hand, it moves freely. When I thread the bolts in by hand, it moves freely. When I add a little torque, it gets just a touch tight. When I go "tight" it binds up so that it takes a few pounds to move the arm. This is with no washers, thin washers, spherical washers on one side or the other or spherical washers on both sides. Can't quite figure out why it won't line up just right. I have an email in to Clint, but am waiting for a response. Any ideas would be appreciated. |
L8apex - Did you check the orientation of the spherical washers, also did you try some additional washers for grins?
Yasin
![]() ![]() I shaved-off 1mm on top and bottom plus machined the block to get same measurement including spherical shims like space between crossmember (plus 1/10mm gap). This minimize the change of angle while torque the member. Also I machine the crossmember, as there are sometimes not very even surfaces and different measurements LH to RH too.
Roland 930 Turbo '81 Too many modifications to list |
Hi
Some of you have used Clint's bushings both front and rear for a few years now. Have you noticed any deterioration? Has anyone disassembled their suspension to see what the teflon looks like after extended use? Cheers! Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
I haven't noticed any change or deterioration at all, I am the creator of this thread so have a few years of driving now with this set-up and it has been solid as the first day I installed these bushings.
Ditto for me - 4 years without a single noise, squeak, clunk, etc. Granted, we're only talking about ~8K miles since installation, but they are just as smooth as on day one.
I replaced a slightly tweaked A arm from racing. The bushings looked great. Much better than my old Polybronze.
I have been having the set on my car for about a year now and love them. The responsiveness and direct steering, great. the only thing is that when riding an uneven surface or when going over speed bumps i get some squeaks from the front. Anybody has the same experience or have a clue what can be the issue?
'71 911 T Original Burgundy |
Member 911 Anonymous
I have that just in the morning or initial drive then goes away. I just try to drive slowly over bumps in the morning until I get her warmed up.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Max Sluiter
No squeaks from me. I thought I did but it turned out it was a little tiny metal clip for a trim piece or something under the dash. For such a tiny thing it was really loud and nearly drove me insane for years!
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Come to think of it. It is my Netrix OEM style rubber rear bushings that squeak in the morning. Please disregard my previous post. Sorry Clint my bad.
hi guys
just received rebel parts for a arm and rear without any installation guide regarding the a arm and rebel bushing the inside cylinder should be mounted free to turn ? or I should glue it ?? thanks for your help try to call clint without success |
Suspension1 http://rebelracingproducts.com/files/RSRFrontBushingSet.pdf
Ed, 1971 911e Targa, 2018 Porsche Cayenne Hybird 68 VW Transporter 2019 Ford F150 Quad cab 4X4 06 Ducati Monster S4R |
Rebel Racing RSR Bushing (Front) A-Arm Install Question
The metal sleeve is bonded to the a arm. Clint is definitely hard to get on the phone. I did the install about 2 yrs ago so PM if you get stuck and I'll see if I can help.
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness |
I love my setup (front pushing, rear 935 spring plates from Clint). I have found him to be relatively easy to get on the phone, though you do miss him at times. When you get hit, he is a WEALTH of info and assistance. He is like the suspension version of Steve Wong (if you have dealt with him for a chip). Clint has even told me not to NOT to buy something from him I wanted to because it would not be noticeable given my setup. How many people do that?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Vintage Motorsport
I'm thinking of doing the Rebel Racing rear bushings.
I love the product but I can't deal with the lack of customer support. Clint never returns phone calls or replies to emails. I still don't believe you should need this many washers to space out the bushings. ![]() The car has never been hit - as far as we can tell. Clint doesn't reply. Your thoughts? Richard Newton LED Garage Lighting |
Max Sluiter
Seems like there is a lot of anti-dive angle shown there in addition to the large stack of spacers, but maybe it's just the picture. I assume you've tried inverting the housing?
