TDIDog's Avatar
Need help unplugging console
I'm installing new carpet and need to unplug the controls from the console. Some of the leads don't seam to have a plug on them Any help would be appreciated.
jack
Old 06-27-2011, 11:32 PM
fred cook's Avatar
911 console........
It would help to know what year your car is. However, assuming that you are refering to the a/c controls, they are held in by way of a nut on the switch shaft. Pull the knobs off and you will see the nuts. They have two slots in the front face rather than being a hex shape. Normally, you should be able to use two small flat blade screwdrivers to remove them. I put one screwdriver in a slot and use the other one as a lever with the switch shaft as the leverage point or fulcrum. Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-28-2011, 04:02 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Gernerally you will find that the easiest thing to do is trace the wiring harnesss back about one foot and unplug the switches there rather than at the console itself. One problem you still still encounter is the thermostat wire that runs to the evaporator in the smugglers box is one long wire and isn't easily removed, try using a 1.5 inch wood bit on the back of the console to enlarge the hole so you can get the switch through it.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 06-28-2011, 05:34 AM
And be VERY careful with that "wire" for the thermostat. It is not really a wire it is a tube filled with gas. If you bend the tube and crimp it closed or cause it to leak you will have to replace it and that is a real pain. As I remember it is a large white "wire" looking thing.
Old 06-28-2011, 06:17 AM
TDIDog's Avatar
Thanks for the replies. I will give that a try. If it gets too tough, I'll just cut a the carpet & hide it. The console covers most of it.
Thanks again. You guys make this site awesome!
Cheers
jack
Old 06-28-2011, 08:18 AM
