Marlon Targa 86's Avatar
Fuse #19 has power then it doesn't... help?
Problem:
Fuse #19 which powers the rear right light assembly measures zero volts with ignition on. When I disconnect the bottom wire connected to the fuse, I measure the full 12.4 volts at the top screw op that fuse.
I connected the bottom wire to fuse #18 ( rear left light assembly) and then all the light bulbs on the right rear work. But when I connect it back to fuse #19, the lights don't work and I get zero volts.
Any clues what's going here?
Marlon
1986 Targa 50K miles - Billstein Sports - Elephant 3 Point Strut Brace - Seine Shifter- Chin Spoiler - Turbo Tail
Old 06-29-2011, 10:40 AM
You have resistance in the supply to fuse 19 >> the resistance of the bulbs. It forms a voltage divider between it and the bulbs. Clean the fuse contacts. Use your voltmeter to see where the drop occurs.
Rick
88 Cab
Old 06-29-2011, 10:50 AM
But how come the bulbs function fine when powered by fuse #18?
Or maybe I'm not getting it? Sorry, fairly new to this fuse thing.
Marlon
Old 06-29-2011, 10:51 AM
Does this explain it?
V(batt): 12 voltage
V(case_1): 11.9502 voltage
V(case_2): 0.142292 voltage
V(case_3): 12 voltage
the 12 ohms is the 12 watts of lights.
the 50 m is the wiring resistance
Edit 1000 is the corrosion on the splice/fuse
Rick
88 Cab
Old 06-29-2011, 12:15 PM
dshepp806's Avatar
probably time for some good cleaning, retensioning and retightening on that fuse block....
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-29-2011, 01:59 PM
Yeah, I think I understand. I'll try jumping across the fuse and see if it works then.
Old 06-29-2011, 02:09 PM
