Fuse #19 has power then it doesn't... help?
Problem:
Fuse #19 which powers the rear right light assembly measures zero volts with ignition on. When I disconnect the bottom wire connected to the fuse, I measure the full 12.4 volts at the top screw op that fuse. I connected the bottom wire to fuse #18 ( rear left light assembly) and then all the light bulbs on the right rear work. But when I connect it back to fuse #19, the lights don't work and I get zero volts. Any clues what's going here? Marlon
1986 Targa 50K miles - Billstein Sports - Elephant 3 Point Strut Brace - Seine Shifter- Chin Spoiler - Turbo Tail Last edited by Marlon Targa 86; 06-29-2011 at 10:44 AM.. |
You have resistance in the supply to fuse 19 >> the resistance of the bulbs. It forms a voltage divider between it and the bulbs. Clean the fuse contacts. Use your voltmeter to see where the drop occurs.
Rick 88 Cab |
Or maybe I'm not getting it? Sorry, fairly new to this fuse thing. Marlon
1986 Targa 50K miles - Billstein Sports - Elephant 3 Point Strut Brace - Seine Shifter- Chin Spoiler - Turbo Tail |
Does this explain it?
the 50 m is the wiring resistance ![]() Edit 1000 is the corrosion on the splice/fuse
Rick 88 Cab Last edited by rick-l; 06-29-2011 at 01:01 PM.. |
probably time for some good cleaning, retensioning and retightening on that fuse block....
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Yeah, I think I understand. I'll try jumping across the fuse and see if it works then.
