Member 911 Anonymous
DRACO A5OG's Avatar
Yeah that sucker is strange. I tried to putting in a LED for the Dash in there but it blew it out instantly.
It's 12 volts but for some reason it will not take a LED.
'85 Carrera Targa
PCA/POC
Old 07-02-2011, 07:56 PM
abit off center
cgarr's Avatar
Didn't the Brits use the same color wire in their cars years ago?
______________________
Craig
G2Performance
Old 07-02-2011, 08:38 PM
Jim,
The source voltage to operate an LED is typically around 2.5 volts. It will burn out @ 12, thus the need for a resistor in the circuit. More here:
LED circuit - Wikipedia, the free encyclopedia
However, there are LEDs designed for 12VDC automotive applications:
www.vishay.com/docs/83099/tlrp4900cu.pdf
Sherwood
Old 07-03-2011, 12:11 PM
DRACO A5OG's Avatar
Hey Sherwood, Happy 4th!
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&category=755&Page2Disp=%2Fspecs%2Fba7s.htm
Well, stange. I got the LED bulbs from SuperBrightLEDs for my dash (supposed already built in resistor) before I installed the EL WIRES. They never blew in the gauges.
I figured since they were the same OD and shared the same Black/Blue hot lead it would just be a plug and play. Doh, NOT!
So if I, install a resistor to that end, it may work, but How will effect the down stream to the gauges? I have the El Wire hooked up to the EL Wire Transformer, I hate for that to be effected.
over,
'85 Carrera Targa
PCA/POC
Old 07-03-2011, 01:45 PM
The electrical engineers were trained at the same school as the AC engineers before 1990s.
Old 07-03-2011, 01:56 PM
dshepp806's Avatar
Originally Posted by nineball View Post
i have, and almost had one. the power wire for the ashtray light was so old the casing was brittle and started flaking off. one day after starting the car the cabin filled with so much smoke i could not see out the window and the culprit was the ashtray lighter wire grounding out. a simple fuse would have prevented the smoke, and my almost heart attach, from happening.
THIS reminds me that I need to revisit that ashtray circuit.....I've long (ago) fused the interior lights at the switch (common mod) but something tells me I recalled the ashtray circuit to not be included in that mod,..of course, I could be wrong...I think I may want to verify that glove box light, as well.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
BA7s LED Bulbs Specifications
over,
You too Jim,
Each gauge bulb holder is wired in parallel with the main gauge light source wire. Thus, you could connect the appropriate resistor in each branch circuit and be good. However, aren't these specific bulbs designed to work in this application as is and w/o an external resistor?
What loads are downstream of the gauge lights? If so, they would also be affected by the dimmer switch (which, btw, should be in the "fully bright" position for the LEDs to operate at their specified voltage).
Sherwood
Old 07-03-2011, 02:19 PM
DRACO A5OG's Avatar
Yes, these LED bulbs were designed for 12V source with supposed built in resistors.
Up Stream would be the gauge, vent/heater levers, Display knobs for the Fog and Defroster and center console heat lever display.
Actually these LEDs dims along with the OEM dimmer.
I am thinking maybe this is the only socket that is not grounded?
'85 Carrera Targa
PCA/POC
Old 07-03-2011, 02:42 PM
djpateman's Avatar
In the late 1970's my '73 914 burned the wire from the fusebox to the highbeam indicator; the whole length. For no good reason I could find. The replacement wire was fused by me.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-03-2011, 02:52 PM
