Closed Thread
brads911sc's Avatar
WWEST
Does a SPAL fan cool your 911?
Why do you so easily take a single case and use it to fit your theory about something else that is far from even similar.
Sounds like you need to do some testing before making assumptions.
After all, you really cant challenge the engineers at Porsche without some proof. can you?
Originally Posted by wwest View Post
Very puzzling...Spal's own numbers.
It appears that Spal's "small sacrifice" rule does not apply in all cases.
30102041 pull/straight 1434 CPM 19.5 Amps
30102042 pull/curved 1864 CPM 17 Amps
30102055 push/straight 1333 CPM 19.5 Amps
30102056 push/curved 1841 CPM 17 Amps
More airflow PLUS lower power draw.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 06-26-2013, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #741 (permalink)
wwest's Avatar
Originally Posted by brads911sc View Post
WWEST
Well, first of all I assume you agree that at least some of the information is patently WRONG. Secondarily no one knows for sure if this information had a factory origin.
Proof..? Doesn't the linked post do the job..?
Old 06-26-2013, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #742 (permalink)
wwest's Avatar
WWEST
See post #734...
Old 06-26-2013, 11:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #743 (permalink)
brads911sc's Avatar
Yes I saw post 734. and?
if there is conflicting info (seemingly) between some SPAL models where curved = less volume and on other models where it = more volume... wouldnt it make sense to find out why before making assuptions about the Porsche fan which is not even the same design as SPAL nor made by SPAL.
See post #734...
Old 06-26-2013, 11:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #744 (permalink)
Banned
Here's more proof for you to refute -
Straight vs. Curved Fan Blades - Dispelling the Myth!
Note that with the 964 Porsche did exactly what is talked about as a negative in that linked webpage - curved the blades and kept the shroud struts straight = big loss in moved air volume.
Old 06-26-2013, 11:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #745 (permalink)
brads911sc's Avatar
Nice write up and research.
Of course WWEST will claim that anything tested on the bench isnt valid. LOL If he accepted this, he would need to accept Griffiths bench testing... and we couldnt have that. That blows up his whole purpose in life. LOL
he will also claim that its false and just snake oil because the research was done by someone selling something... to accept this would expose his double standard when it comes to GTI. of course those standards dont apply to SPAL since he bought their snake oil.
Old 06-26-2013, 11:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #746 (permalink)
brads911sc's Avatar
they are just selling snake oil.
cant trust that bench testing.
30102041 pull/straight 1434 CFM 19.5 Amps
30102042 pull/curved 1864 CFM 17 Amps
30102055 push/straight 1333 CFM 19.5 Amps
30102056 push/curved 1841 CFM 17 Amps
Old 06-26-2013, 11:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #747 (permalink)
wwest's Avatar
Thanks much, but I think I'll stick with Spal 's square vs curved blade "numbers", and their curved blade fans that includes those "winglets", or Ebay replicas thereof.
Oh, the naysaying..where is the power draw chart and/or relative RPM between the 2, for one vs the other..?
Old 06-26-2013, 12:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #748 (permalink)
brads911sc's Avatar
Why ? because you paid money for the snake oil?
Old 06-26-2013, 12:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #749 (permalink)
brads911sc's Avatar
SPAL could never lie. I own those. LOL so predictable WWEST.
Old 06-26-2013, 12:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #750 (permalink)
Banned
Question - if the 964 curved blade fan moves more air, as wwest claims, why do you suppose Porsche put the straight blade fan on the 964 turbo which generates far more heat than the non-turbo 964? Do you think it was because Porsche wanted it to run hotter and thus promote even more frequent engine overhauls?
Old 06-26-2013, 12:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #751 (permalink)
brads911sc's Avatar
WWEST operates from a SPAL fan snake oil perspective. not one based in logic or fact. so doubt you will make him understand what you are saying... this stuff is just too complex for him to comprehend.
Question - if the 964 curbed blade fan moves more air, as wwest claims, why do you suppose Porsche put the straight blade fan on the 964 turbo which generates far more heat than the not turbo 964? Do you think it was because Porsche wanted it to run hotter and thus promote even more frequent engine overhauls?
Old 06-26-2013, 12:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #752 (permalink)
Banned
Right - it's not every day that your run across someone that ignores facts and/or logic simply because they are trying to save face in a discussion over something as simple as fan air volume.
Old 06-26-2013, 12:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #753 (permalink)
brads911sc's Avatar
truly unbelievable. you should see his posts over on another thread. just as crazy and insane. over there the entire premise is about engine heat. AC is secondary. the guy doesnt even have AC yet... turned the entire thread into a Spal fan and trinary switch discussion. LOL
Pre AC project - getting the car's temp down!!
pretty entertaining...
Old 06-26-2013, 12:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #754 (permalink)
wwest's Avatar
---------- Forwarded message ----------
Date: Wed, 26 Jun 2013 11:50:02 -0700
Subject: RE: A1 Electric Email Form
To: wwest
Yes, going by the current numbers that Spal has published, it appears that
the curved blades perform better.
A1 Electric Automotive Accessories
2301 W 205th St Ste 101
Torrance CA 90501
(888) 838-0506
(310) 328-8500
A1 Electric Automotive Accessories, Power windows, Power door locks, keyless entry systems, Window motors, Window regulators, Pop door kits
-----Original Message-----
Sent: Wednesday, June 26, 2013 11:10 AM
To: info@a1electric.com
Subject: A1 Electric Email Form
Below is the result of your feedback form. It was submitted by
wwest on Wednesday, June 26, 2013 at 14:09:37
Vehicle: 1988 Porsche 911
Comments: Your FAQ answer "sacrifice a small performance level for/with
curved blade fans vs straight blade fan does not appear to hold true for the
clear majority of your products....
Old 06-26-2013, 01:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #755 (permalink)
brads911sc's Avatar
Lol Snake oil. Sales pitch doesnt match their FAQ. Snake oil.
No one cares WWEST. This is a Porsche Forum not a SPAL forum! Put this with the lexus and ford references. as an aside... If the same thing happened on GTI site (like the hose argument you sited). you are all over it. whats with the double standard?
I guess I seriously dislike marketeers pretending to be "professionals" that spread disinformation in the process of selling their own "snake oil" product(s). Given Kuehl's expereince level I have no doubt that he knows the truth (ignoring the possibility that he has long sense forgotten) but it doesn't serve him well at the moment.
Old 06-26-2013, 01:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #756 (permalink)
Banned
Back on topic - come on wwest, what say you? Do you think Porsche wanted to run the already much hotter 964 Turbo at an even higher temperature? Or maybe they are just all dip****s over there and couldn't see the logic in running the curved blade fan?
Old 06-26-2013, 01:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #757 (permalink)
Banned
Ha ha - thanks, good read!
Old 06-26-2013, 02:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #758 (permalink)
wwest's Avatar
Okay, here is a naysayers DELITE!
I would suppose that with the higher efficiency of the curved blade fan spinning it at the speeds required to cool the turbo resulted in "compressor stall" or as some would say, "cavitation".
At what speed relative to the engine does the 964 turbo spin the fan..?
Old 06-26-2013, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #759 (permalink)
wwest's Avatar
Note: "Stalled Condition"
Old 06-26-2013, 02:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #760 (permalink)
Closed Thread
