really cool photos and what you are doing :-) Yes I am just getting my 63-89, 911 condensers off the ground so at least at the moment I am a bit busy <grin>. On another subject I have been thinking for sometime about making Paralleled Flow heat exchanger for OIL COOLERS However believe I can build basically any size dimensions I want length and width, and also curved for a Paralleled Flow heat exchangers, think about these possibilities. FYI; perhaps you should not think so much like you are about thickness of a Paralleled Flow heat exchanger being so thick like you probably are for heat exchangers that are made of tube & fin; serpentine, plate & fin, etc !! The technology of Paralleled Flow heat exchanger coils for almost any purpose is far more efficient than any other heat exchanger technology invented before it in the neighborhood of 30-45 percent, not only that but the size can be maybe 25-35 percent smaller than previous technologies and still attain the approximate efficiency I stated. To not split hairs it greatly beats anything for before and size can be smaller when using as a heat exchanger. Try thinking outside the box But it gets better; it can probably also be used as a multi-tank heat exchanger, this means successive tanks working coupled together as one to enhance each one, have smaller overall size and further increase efficiency, plus the components can be further micro-processor controlled (computer) Example DENSO Manufacturing Michigan, Inc. Example This is where the world is already quickly going http://www.r744.com/knowledge/papers/files/pdf/pdf_138.pdf |
Flintsones air-conditioning
http://forums.pelicanparts.com/uploa...1311726108.jpg
http://forums.pelicanparts.com/uploa...1311726154.jpg currently only has the 2 rear side windows talk about air-cooled air-conditioning hehe he The marks on the rear left tire are caused by the Finstone family together operated wooden stick brake pad for slowing or stopping Pebles and BAM-BAM ride in the back |
How would you determine the size of a micro-channel condenser required for a cabin the size of a 911, operating in the southwest summers (100+ most of the time). It is just my guess that 5.5" x 24" would not be enough. That is why the question regarding stacking 2 front to back. Reduced efficiency at the rear condenser may be a problem, this is what I do not know. The flow could be continuous thru the two entering one and then flow into the second and then exit to the dryer.
Ok,
Have some measurements. These are rough guesses but a start. Can you get anywhere close to: 10 X 14 10 X 12 11 X 11 Thx, Joe |
I make custom A/C Paralelle Flow condensers for for 911 Porsches built from 1963-1989 that are up to 40 percent more efficent then any other condenser you can currently buy on the open market anywhere to my knowledge. if you want to know more about Paralelle Flow condensers technical aspects read this patent it might help you click here >>HEAT EXCHANGER WITH MICROCHANNEL, PARALLEL FLOW, ALL-ALUMINIUM FLAT TUBE WELDING STRUCTURE AND ITS APPLICATION - Shanghai Oriental MHE Co., Ltd. Abstract: HEAT EXCHANGER WITH MICROCHANNEL, PARALLEL FLOW, ALL-ALUMINIUM FLAT TUBE WELDING STRUCTURE AND ITS APPLICATION Document Type and Number:United States Patent Application 20110139420 Kind Code:A1 Abstract:The present invention discloses a heat exchanger with microchannel, parallel flow, all-aluminum flat tube welding structure, wherein the heat exchange part of the heat exchanger is formed by flat tubes composed of extruded thin-wall aluminum profiles in parallel arrangement. Compared to existing technology, the present invention has the following advantages: 1. The heat exchange efficiency of refrigerant and the inner wall of flat tubes is increased by 40%, and the flow resistance of the refrigerant in the heat exchanger is reduced by 40%. 2. The heat exchange efficiency of fins on air side is increased by 40%, and the wind resistance of the heat exchanger on air side is reduced by 40%. 3. The heat exchange performance of the entire heat exchanger is improved by 40%. 4. The refrigerant covered is 40% less than that in the conventional technology. 5. All-aluminum structure features longer service life due to no copper-aluminum potential difference when comparing with copper-aluminum structure. The flat tubes adopted by the present invention are provided with the advantages of resistance to high pressure restricted by the existing refrigerant, compact product structure, light unit weight, short process flow, and high manufacturing reliability and relatively low cost. The present invention also discloses the application of the abovementioned heat exchanger. |
I have been talking to RennAir
I have been talking to Cab the owner of RennAir for several weeks, they contacted me after reading here about my condensers, they do not make condenser and expressed an interest in my PFC’s for their clients.
FYI; When I was having Freon line connection problems with a tube and plate evaporator I had been developing for Porsche that was greatly slowing me down from testing my condensers Cab was very kind and sent me one of Rennair’s 911 Serpentine evaporators and thermal expansion valves, which allowed me to finish my testing temps that I reported here; To return the favor I am sending them the matched set front and contour rear deck lid condenser, its going on a 911 that one of their special clients who is very excited about my technology. The car has been properly prepared, will get a RennAir Serpentine evaporators, RennAir PRO-COOLER, both my PFC’s, new compressor and a/c lines plus the evap box fully insulated etc. After the installs it will be fully tested and publish the results here; I expect this 911 they are prepping to get very cold to say the least due to Rennair's expertise |
What are they doing about the evap blower. Are they now providing a stronger fan motor like other two major players are?
reid, the phone number YOU wrote(954) 599-5234, which i called TWICE and got a "stacy", does not seem to sell a/c parts.
so bottomline.............ya wanna sell some condensers? like 3 for starters. because my hot lil grubby hands are dying to burn a VISA/AMEX card this very instant so we can start our a/c projects before we get old and die! so ya have it in writing,what we are looking for: (1) front condenser for a 1985 targa oem placement (1) front condenser for a 1987 cab oem placement (1) rear condenser that fits in oem placement 1987 cab whale tail do you have these in stock and avail to ship asap? AND WHAT IS YOUR correct phone number SO I CAN contact you ? |
The Evolution of the progression for condenser and heat-exchangers technologies
http://forums.pelicanparts.com/uploa...1311787532.jpg
Parallel Flow Condenser Efficiency: Parallel flow condensers maximize the cooling ability of the refrigerant in two ways. 1.On average, a Parallel Flow condenser is 5/8” to 1” in width and consists of not one tube, but many (commonly 10 to 12 or more) passages per flat micro-channel tube, and from the outside looks like a single tube (« see diagram). 2.Instead of having one giant round tube where at least 75% of the refrigerant is not making contact as it flows through the condenser, a Parallel Flow condenser’s passages are between 1mm and 2mm maximizing refrigerant contact to the outside walls and therefore maximizing heat transfer. When converting to R-134a refrigerant in a classic car, one of the key components to be addressed is your condenser. The original tube and fin design condensers that were commonly used in classic cars struggle to keep up with the increased pressures brought on by 134a refrigerant. This often leads to warmer vent temperatures and premature component failure. And that’s just not cool! If you replace the factory tube & fin condenser or other prior technology type of condenser with a parallel flow condenser you will increase your vintage auto’s air conditioning system efficiency by approximately 33%. The result: cooler vent temperatures, increased fuel economy, component and system life. It will even help with your R12 system if you have not upgraded to R-134a refrigerant! Here are the chief benefits: ◦Dramatically increases system efficiency. ◦Increased fuel efficiency, due to less engine wear. ◦Ideal for converting to 134a, but also improve systems using the old R12 refrigerant. ◦Clean, attractive appearance. ◦Direct replacement, with no modifications whatsoever to the vehicle. Stay Cool! |
My telephone NUMBER IS (954 599-5235
My Correct telephone NUMBER IS (954) 599-5235 in Fort Lauderdale, Florida
The number is for my mobile phone, Fort Lauderdale is in the eastern time zone same as New York I had posted my number correctly a couple of times here but I made a typo that had the last digit of my tele number as a 4 only one time in a privious page and which I have now edited it and corrected after being notified it was incorrect I would post my email address here publicly; but I dont need a ton of spam from Nigeria Africa the bank fraud capital of the world, so if you would like my email adress feel free to Call me directly or you can send me a private message here. To let you know I am a bit backed up answering my private messeges here because I have been very busy and it takes a long time to properly write proper message replies; please excuse me if you have written me a private message I will try to answer them as soon as I can find the time; but please know you can always call me directly if you are tired of waiting Best regards, Reid |
I cannot believe you do not want to get LOADS of emails from Nigeria!!! :)
I was based there for around two years, flying all over the place and trust me, its a lot worse than most can imagine. Thanks for the contact info, we will be in touch! Joe A |
Looking forward to talking to you Joe; Besides several other things I do I am a USCG Licensed Captain on smaller vessels and also a USCG Licensed Chief Engineer for vessels up to 3,000 tons; as well as a professional marine mechanical engineer; Although I usually work on Private Super Motor Yachts, (“Superyacht” and "Large Yacht" refers to very expensive, privately owned yachts which are professionally crewed); I have had several well paying job offers over the years working off the coast of South Africa and Also Nigeria in the offshore oil industry and from this area of the world; so in the past I have thoroughly checked this area of the world getting pretty good info I think how things are and what its like to live & work there, lol and its not for me; I am also a computer expert and have been online since 1986 and I got to tell you that the majority of the worlds internet driven bank fraud money scams come from Nigeria; so a word to the wise is to always beware of any emails coming from Nigeria or that has any reference to Nigeria in them for any reason and this part of the world over all others! Ohhh, I bet you have flown to a few oil rigs too <grin> |
is your 911 with the later model 1990-91 plus, 3.6 engine a Turbo? I ask because we had in the shop a 1980something 911 turbo; that had a newer updated 1991 3.6 turbo engine I think it was; installed and I looked at it for a few moments; and it has a much larger intercooler and there is no way my deck lid contour condenser would work with this engine. because when I lifted the deck lid to look at the A/C I thought it had, it was apparent my contour condenser would not work; because the intercooler air intake is so huge and almost touches the deck lid air intake sheet metal almost all of the air hole hole, and the owner I think was using a Griffiths condenser in another place in the body for his A/C sys. I think my deck lid contour condenser MIGHT work with the orginal earlier turbo engine it had before? But with this more modern 3.6 turbo 91-92etc. engine and its huge intercooler there is no way! I know in your case you are using an RS deck lid or similar, and now after seeing this car I now understand why it won't work for you I did not understand before This is the car with the I think 91-92 Turbo engine, the condensers are leaning on it so I could see how they would fit, and what a surprise to learn when I talked to Justin Stokes the engine was from a later year Turbo http://forums.pelicanparts.com/uploa...1311830850.jpg |
Reid,
I used to fly one of the guys who owned about 30% of the oil production and half of the banks in Nigeria. An absolute crook in some areas, but took very good care of us. We were based in Lagos but flew to most of the airports in the country, including where you probably docked, Port Harcourt in the delta, the hub of the oil production facilities. Also the kidnapping capital of that part of the world, its not for the faint of heart. Yes, been to an oil rig or three... My 911 has a 1992 3.6 in it but its a normal engine, no turbo. The car has a ducktail style spoiler/decklid on it and just no room back there for the original style deck mounted condensor that worked on the car when it was stock. Wonder if two of the smaller condensors pictured above would be enough to cool a 911? Put one in the original position under the front bumper and a second in one of the wheel-wells? Would have a fan on both of them but also am leaning towards not using R-134 but R-12, which cools a bit better. BTW, in about two years of flying in Nigeria I made a couple of friends there. Three of them turned out to be pretty nice people and out of those one, only one was a person that I felt that I could really trust. The rest were worthless. BTW, the one that we all felt we could trust and a really nice guy, a gent named John Cooper who was not Nigerian but from Liberia was murdered 15 months ago. Sad to see... |
Prices for Pelican users that have been a registered user before today
After much soul seaching I have finally decided on prices
FYI; I have an ebay listing now that includes both front and rear condensers for the general public I will change as I decide too. Besides my personal marketing my products will soon be made available to Porsche after market parts world wide distributers, and maybe to specal dealers Oh Not to forget Pelican Parts, I will offer my products to them too. Pelican is a good company! I suggest you do not use ebay for my condensers if you want them and you're a registered user here! because if you were registed before today you will not have to pay the ebay listing price and will receive a substantual discount when I verify your registration date here If you would like to know the specal prices I have decided on for people who are registered users here on or before today Friday 7/29/11 private message me Ohh I am further thinking of making PFCs for other model Porsches and I might make them? depending on demand Note: I will soon be offering complete kits including PFC's, evaporator, hoses & connection fittings, reciever dryer, maybe even PRO-COOLERs, etc. etc. Oh and I almost forgot Justin Stokes@Stokes Automotive a 30 year Porsche repair company will do custom installations & rework for those that would like high quality A/C work & service here in south Florida to Porsche Standards for Excellence and DEMANDS COLD |
Would a kit look something like this?
Request for quote: R12 to R134a Car: 89 3.2 Coupe 1 - Sanden 507 Compressor 2 - Bracket for Compressor 3 - full barrier hose kit, all seals/etc. 4 - new receiver dryer 5 - better rear condenser (micro channel?) 6 - better front condenser (micro channel?) 7 - over/under pressure switch 8 - correct expansion valve (assume evaporator is good enough) 9 - inline filter(s) to protect expansion valve and/or compressor 10 - mechanical install instructions, will take to shop or your shop for filling if within reasonable driving distance 11 - oil if doesn't come in the compressor options: 12- new evaporator Parts are to be bolt up compatible or easy modification, e.g. no front condenser hanging down, fits in the stock space. What is wrong with this kit? Adds? I don't want to add condensers e.g. under fenders/etc. I feel like better design condensers available now compared to 25 years ago or more should get the performance needed. Max. dry bulb 103F. |
you need more because you don't think two micro channels is not enough condenser performance?
My system has not worked in years according to the PO. In fact he sold the car as he was moving Miami and was concerned about a cab with no AC. I plan on doing all the work, with the notable exception of filling the system. |
Thx, Joe A |
Multi-flow condenser old technology
I know there are many do it yourself your way people in this world, because I am this way too <grin> so I write this to those that are on extreme budget but still want their 911 ac a bit colder so I write this for YOU because I care about people and want to help YOU
This is also written to others who want knowledge about technology history Please understand and do not be offended I am extremely limited due to patents pending to discuss the state of the art technology I am using, but I can discuss older technology I have rejected and don’t use, however it’s a waste of my time to spend much time for me to discuss older technology to educate very much for obvious reasons http://forums.pelicanparts.com/uploa...1312039032.jpg picture is of a "MULTI-FLOW CONDENSER" "USING OLD TECHNOLOGY" (compared to what I use); installed into the rear deck lid of a 911 by a well known 911 A/C conversion company that does work a little better than some are selling but not the best. "Multi-flow heat exchanger" is a several year old technology but IS newer and BETTER (more efficient) THEN serpentine or plate and fin technology FYI This IS NOT the technology I am using! I am using the latest state of the art technology after a four year engineering research project study and development developing my own patent pending products I will change in a heartbeat to a better technology the moment it is discovered and my quest for knowledge in engineerng constantly continues many hours every day, this is the difference from what I am doing compared to others Speaking of others this picture is a simple UNIVERSAL CONDENSER publicly available for about $150 including shipping; if you do enough reading about aftermarket 911 condensers you will find it By the way I have one of these UNIVERSAL CONDENSERS (not pictureed) I tested some time ago out of curiosity for a couple of months and it does work much better than any 911 OEM deck lid condenser when using R134A Freon; NOTE: if anyone is short on funds for my rear deck lid contour condenser and wants one like I have shown here in the picture I will sell it for $100 plus shipping; BUT DO NOT EXPECT IT TO GIVE YOU WHAT MY PATENT PENDING CONDENSERS WOULD GIVE YOU! |
Could you give us the dimensions for your FRONT condensor. I am looking to see if it will fit in the front oil cooler position of the 73 rs type front spoiler. I currently use a factory front condensor in this space.
I think Boba is also looking at a similar solution. |
Sent ya a message concerning prices on front and rear condensers..Waiting to hear back...Thanks !
I sent you a pm regarding a condenser for my 75. Waiting to hear a price. Thanks.
Thank you for your question! its a hair over 6 inches wide and length about 22 inches or so. But this PFC wont fit; its made for under and between the front wheels of a 911, 912, 930 FROM 1963 to 1989. You are the second person who has asked me about a PFC for the front oil cooler space (probably Boba) for riding adjacent in the rectangle to the Oil Cooler on an RS. To be honest and I always am; although I could make a PFC that would perfectly fit this space, the developmental time and engineering cost are not really worth it to me for my return on investment, because there are so few RS's, and I could only sell a few each year at most, FYI; I am pretty busy with other current projects already, and I am also considering other projects as well, which show promise in far larger markets Best regards, Reid PS MAYBE i WILL CHANGE MY MIND AND MAKE THEM FOR RSTs / RSs IN THE FUTURE I am strongly thinking about making some for the 91-92 plus years & TURBOs that have the huge intercooler intake, the also including C2/C4s and those that might want/need fender units very soon; |
Sent you a pm as well. I have been following this thread with interest.
Porsche A/C BEFORE 1974; Did the 1971 Porsche 911T Targa include air conditioning
At Least for my Front Condenser or even a Front Porsche OEM 5 inch wide condenser These early Porsche Cars MAY NEED SOME MINOR MODIFICATION IN THE FORWARD UNDER SIDE BODY AREA TO ALLOW EVEN A PORSCHE FACTORY FRONT CONDENSER TO BE INSTALLED!!! For this you need to have the front underside of your of your 911 or 912 car ALSO even a 914 looked at by a Porsche mechanic TO ADVISE YOU WHAT YOU NEED TO DO TO INSTALL A/C for the first time on your car. ================================= Or maybe you can search the internet for this information to get some answers It is my hope that one of the A/C repair experts with early year Porsche experience or someone with experience on older cars will write here about this and share their experience and knowledge on these cars for what will be needed As for the Rear deck lid condenser I think my contour rear deck lid condenser will fit your deck lid because I think the main part of the OEM deck lid's where the rear A/C condenser can go are basically the same for 63-1989 911/912/930 model years; But I really do not know for sure yet and if anyone does and I am wrong please let me know, I do not want to accidently misslead someone because of my lack of knowledge ================================================== ======== Porsche 911 Did the 1971 Porsche 911T Targa include air conditioning - JustAnswer Porsche 911 Did the 1971 Porsche 911T Targa include air conditioning Submitted: 143 days and 10 hours ago. Category: Classic Car Value: $30 Status: CLOSED Optional Information Country: Canada Make: Porsche Model: 911 Year: 1971 Accepted Answer DR. Hamman : Hi, I will do my best to assist you. When you are finished please click on accept. I don't get paid unless you do. I don't know if you are a pro or a novice so we may have to fine tune the answer. I only know as much about your problem as you have told me in your post, so my answer will be based on what you have posted. Feel free to add any additional info you feel is needed. In 71 the 911T was the base model, and the Targa option was an upgrade, but it didn’t include AC. AC was a rare option for a 911T because most of the time if a 911 had lots of options it would be the mid range 911E, or the 911S which was the top end of the model lineup. AC was available as an option on the 911T, but it is a very rare option on the T model. I rebuilt an engine on one of these in the late 70's and the AC complicates the engine compartment As I remember, the compressor was on the drivers side. The Targa option is also fairly rare on a 71 T model, not near as rare as the AC though. If you have any more questions I am here to help. Good luck, and Thanks for using Just Answer. I hope this helps, 100% satisfaction is my goal. If the answer is not clear, please reply and I will assist you more. When you're satisfied, click on accept. I don't get paid unless you do. A bonus and positive feedback are always appreciated, good luck and Thanks. Expert: DR. Hamman Pos. Feedback: 99.2 % Technician I have 30 years experience repairing, restoring, and customizing cars, and pickup trucks. Ask this Expert a Question > Related Classic Car Questions Question Date Submitted Porsche 911T Ive inherited a 1971 porsche 911T. Its in 7/5/2011 |
want to say something
I want to say something again about this picture I had uploaded almost a month ago
I said when I uploaded it that "IT IS STATE OF THE ART EXTRUSION TECHNOLOGY" THIS STATEMENT IS NOT COMPLETLY CORRECT!!! What I should have said IS "IT "WAS" STATE OF THE ART EXTRUSION TECHNOLOGY A COUPLE OF YEARS AGO" +++ "It"s NOT WHAT I USE TODAY!" ++++++++++++++++++++ "THIS MICROCHANNEL TECHNOLOGY "IS OLD" COMPARED TO ANY OF THE MICRO-CHANNAL TECHNOLOGY THAT I USE IN THE PFC's I MAKE" FYI I am unfortunately prevented from discussing ANY SPECIFICS ABOUT THE STATE OF ART TECHNOLGY'S I AM USING IN THE DEVELOPMENT OF MY CONDENSERS for obvious reasons But I will say this because you might like to know; I am in contact with several micro-channel extrusion materials manufacturers worldwide; this technology is sometimes being updated DAILY, sometimes several times in a day worldwide, and new patents related to this technology are flying to the forefront of known knowledge, due to public patent disclosure and it is simply amazing what is going on in this field scientifically related to heat exchanger coils to say the least. Regardless of what I might be doing at the moment with what I am making today, I have the unique ability and knowledge to switch to a new technology the next moment in time to the latest state of the art technologies the moment it becomes available and to change what I am doing in a heartbeat. My competitors who try to reverse engineer and/or try to steal what I do’ i have a surprise in store for them, because it’s easy for me to render anything I have made in the past immediately obsolete the moment I discover it, with a newer far more efficient design the next day. For my business competitors who developed their own products and designs I welcome this and intend to have a good and friendly relationship with them!!! Most Important I want to say I care about people; and also we owners of these fine older Porsche cars have suffered long enough and I am determined doing something about it for US ALL!!! See what can happen when someone gets angry when they know something exists to make their 911 a/c colder then is made for 4 years AND they can not buy it anywhere and are forced to make it themselves. <grin>. Never in my wildest dreams did I ever expect to be making heat exchangers for other Porsche owners, but thanks to you guys here @pelican forum this is what I have decided am going to continue to do; and I vow to make them as best ! can to the highest standards of and to the memory of Dr. Ferdinand Porsche and for the owners Who are lucky enough to have them. Who knows maybe after I am gone someone will remember I tried to contribute something to make life a little better when we drive our wonderful Porsche car Reid Quote:
Reid |
Reid,
Yes, I got it. Thanks. I will most likely be a customer very soon. My 75 doesn't have a front condenser just the rear. And I expect it came that way from the factory. Either way, it has to be better than whats there now and what hasn't worked in years. Spencer |
KelogGes, what are your thoughts on replacing the compressor with a scroll-type vs. the 507, I've heard they're more efficient and sap less power from the engine- obviously this would require a custom bracket of some type...
Front Condenser: I am surprised you don’t have a front condenser because it is the same year as mine and yours is also a Silver Anniversary Model, but maybe you’re a/c was not factory or authorized dealer installed, and/or unless someone who owned it before you, had it installed because it never came with A/C? However I am the 4rd owner, my 1975 I have owned for somewhere between 15 to 20 years and I have been told by people who know Porsche A/Cs that mine was a dealer installed Porsche factory option after the car was shipped originally from Germany to California to the dealer without A/C and the original new owner wanted OEM factory air so the factory authorized dealer in California installed it instead of the factory in Stuttgart using OEM Stuttgart parts, i.e. BEHR and Porsche parts. About Front condensers on pre 1989 911s, without going into a lot of 911 history problems I have read about and everyone knows about; the front condenser makes a big difference further increasing the condenser efficiency phase change of the high pressure hot gas to liquid of the A/C system coming fromg the rear condener in the 180 plus degree hot engine comportment; even when using R-12 which was originally used and much colder then and more efficient then R134A Freon. One of the many reasons the car needs the front condenser I do not have time today to elaborate i.e is stop and go traffic and at idle it really makes a big difference; furthermore the more condenser surface area the A/C system has the better it works to further cool the gas coming from the rear deck lid condenser to phase change the refrigerant high pressure gas to LIQUID your evaporator NEEDS AND IS STARVING FOR IN ORDER TO MAKE COLD! YOU ALSO NEED BLOWER FANS FOR THIS “BLOWING AIR THROUGH THE CONDENSERS” NOT AROUND IT to make the condenser work good and do its job!!! OR you shoot yourself in the foot! 911s prior to late model 1989 all had a A/C design flaw; the car BODY never was designed to be used for ANY A/C system; and this was never changed by Porsche from 1963 to early 1989; when Porsche finally changed the original body design, and completely changed the classic 911 to a new car design and in my opinion ruined the beauty of classic 911 forevermore. 911s prior to late model 1989, All A/C systems are/were extremely starved for adequate condenser surface area from day one, and this is why Porsche finally added the front condenser to cars shipped to the USA sometime I believe in 1974 model year and still it sucked and people continued to sweat driving when the outside ambient temps increased above maybe 80-85f or so. Porsche even came out with a BELLY PAN full width under the car condenser to be used in addition to the already being used rear and front condensers which only helped a little better back in the R12 days but not very well, where it gets hot driving. The BELLYPAN had no fans, and picked up road heat from the road a few inches under the BELLYPAN condenser option. The car has been cursed with inefficient a/c CONDENSERS since Porsche first made AC work in 911s;, it got cool but not cold in warmer climates because their was not enough room for adequate condenser heat exchanger surface area. Were I live in Fort Lauderdale in south Florida due to the high humidity caused by being in the equator TROPIC ZONE is one of the worst places in the USA that extremely taxes the efficiency of any A/C system to say the least, because although we regularly get an ambient temp heat of 91F the evaporators here cant evaporate effiencly like they can in lower humidify areas and are daytime heat index temp is equal to 120 plus degrees F and sometimes its this way day and night regardless of if the sun is shining or not, god I dread August and September here lol its simply THE PITS! MOST people don’t know but it is actually feels cooler for humans in places where it gets very hot ambient temps i.e over 115-125 like the desert hot places in Arizona, New Mexico, Nevada and the areas of the Mohave Desert in California; because THIS IS DRY HEAT WITH ALMOST NO HUMIDITY compared to here here in the tropics; because when we sweat here the sweat says on the skin trying to cool the body so that body sweats more and more but the body cooling is minimal and you stay wet, in these hot arid places when you sweat the moisture your body produces is quickly sucked off your body by the extremely dry air in the desert and it cools your body! HERE IT DOES NOT like it does in the desert or arid places!!! The patent pending condensers I have designed and am making completely revolutionizes the cooling effect potential of every late model 1989 and earlier year 911 Compressor I replaced my original piston type York piston compressor with a Sanden and with a mounting adapter I bought from Vertex in Miami more then 10 years ago, and about 6 months ago I replaced my different model Sanden with a new fully chrome plated Sanden 507 I bought off eBay for about 200 after talking to several people about it, and making sure it was a USA factory made model and not the ones made in china factories. I am very satisfied with the 507 I am using. FYI I was in a large a/c compressor rebuild shop recently looking to find special aluminum 0-ring connection fittings I could modify to use for braising on to my condenser designs and I got into a conversation with the manager of the compressor rebuild shop about my Sanden 507and he told me after rebuilding 10s of thousands of all the different models of compressors Sanden 507 is one of the best he has ever seen for many technical reasons he told me about, even though the 507 model has not been made very long. Before I bought the Sanden 507, I researched compressors on the internet for weeks and everywhere I read sandon 507s were considered the best compressor for the money, and it compared to compressors that cost many times more. What is also nice is there is an aluminum adaptor kit made for this compressor made by Sanden that fits 911s,912s/930s. Porsche factory have newer replacement upgrades to the York piston compressor that is a newer type non piston rotary type available for these same early model Porsches and with it a much higher cost (ouch ). So I do not know what to say about this compressor you are telling me about? I could get you into a discussion about rotary vane compressors, versus the new wobble plate designs, piston and several other high end different types of refrigeration compressors that can cost well over 2 grand and much more but I think you should get what is proven to work well and I would suggest you get what the majority of the Porsche after market people are using that has been proven to work well and is the most cost effective. I more than welcome anyone reading what I said to also feel free to give your experienced opinion to help 911 owners here!!! And most of all please correct me if I am wrong or don’t have something quite correct! To the readers of this forum tread please know that there are some of the very best and well known experts in Porsche A/C technology reading here in the background that sometimes post excellent advice (I won"t identify so they can retain their privacy) I think that when I start making kits available soon I will offer Sanden 507 wobble plate compressors because my experiences with them and of their aftermarket proven 911 track record and their popularity and price |
Hey Reid,
You need to post here: http://forums.pelicanparts.com/porsche-911-technical-forum/622224-if-you-could-build-ultimate-c-system-scratch.html Joe A |
are you making these for 930s?
! make them for for 930s <grin> This is exactly what my PFCs were designed for I guess you have not read what I have posted in this forum? |
Sorry, I must have missed that...... I got lost in all the posts
Thanks Frank |
