Closed Thread
LinkBack Thread Tools Rating: Thread Rating: 34 votes, 3.53 average.
Originally Posted by wwest View Post
"..how much airflow does the condensor need to work at an optimal level.."
Difficult question that..!
Yes, but I wasn't speaking of idle. My original point was the HEAT soaking of the condensor post engine shutdown.
Heat soak is an issue, that 250kg of hot metal, when parked, only has one way to get out and that is through the same condenser that was cooling you a few minutes ago. I think it would labour for a while until you got some real airflow through it.
Just checked with Bruce Anderson's book, my fan pulls 1380 litres per second at 6000 rpm, so if one assume linear flow (likely not true, it almost for certain tails off at higher rpm) then at idle one is drawing about 200 litres per second (about 7 cu. ft. per second or 420 cfm) so a decent flow even at idle. Certainly I notice that at dead idle, my AC is not quite as cool ( I have left the thermometer in the vent while I check out the system), I see about 40-45 F in traffic idle, and about 36 F best case while cruising (all temps at 28 c outside temperature).
I started on the math for the heat extraction capacity of this airflow, but ended up needing to know such esoteric things as the temperature of the condenser under load....but it is .569 watts per cfm for a 1 degree C change. So very simplistic calculation ought to show that if the condenser is 10 c over ambient, at idle I came up with about 2300 watts of heat extraction capacity in the air with the air leaving the condenser of course 10 degrees higher than it went in. And then I got lazy....get into transfer efficiencies ...
Empirically it works and the practical side says leave it at that...
D.
Old 08-03-2011, 07:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #181 (permalink)
ratpiper71T's Avatar
Quote de ratpiper71T
Just to add...I had originally told Reid I have a front condenser on my factory AC equipped '71, but after a further look it appears I don't have one.. Any other early car users have only a rear condenser??
Yes you did
ratpiper71T got a surprise for you comeing in a few days :
Stop what you are doing on your toy or at least slow down until you read it, as it will extremly help you to say the least. (Speaking of saying I cant say much at this time)
I am doing something with RennAire (wink) related to a 1971 911; you will read about I think maybe next week .
Cool.. Now I'm intrigued. I'll hold off on ordering until I see the surprise, then. Glad I haven't pulled the trigger on purchasing the rennaire kit from pelican, yet. And glad you're teamed up with them as maybe I'll be able to get this part of the resto planning locked up.
Old 08-03-2011, 09:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #182 (permalink)
wwest's Avatar
Originally Posted by KelogGes View Post
BGCarrera32; No disrespect back to you too!
First you have made comments about a picture you know nothing about and furthermore you have completely taken your comments out of context for what this picture represents or why it was posted!!!
Did you not read what I wrote and said about these 2 pictures before making your negative comment???
Picture Subject caption “THE ROCK GUARD NEEDS MODIFICATION”
*The description words posted with it to explain*
“I just uploaded these pictures and do not have time at the moment to write the discription and what will be needed”
“I will re-edit this to explain so you understand better about this subject”
Lets clue you in;
These 2 pictures have to do only with the “MODIFICATION of the OEM 911 ROCK-GUARD” and adapting the OEM 911 ROCK-GUARD to fit my Patent Pending Front Condenser<<
My Patent Pending condensers need no modification they were specifically designed to be exactly what they are and appear to be for good engineering reasons; furthermore I am not going to discuss with you or anyone here the technology or specifics because they are Patent Pending,
MY test result prove they work as designed or better.
FYI: I have no intention of making perfect replacement exact fit of the original dimensions of the 911 OEM extremely old technology Porsche/Behr condensers, and have never claimed this!!! Furthermore; if you had read my whole tread here I stared and all of my posts, you would have read of my almost complete refusal to do this when someone asked me here almost a month or so ago, and why I told them I did not intend too!
Where did you get your degree in thermal dynamics and/or also mechanical engineering?
What professional experience do you have in these fields?
How Many A/C heat exchanger condensers have you invented, or made, and what was the technology you used?
What is your scientific experience, background, and knowledge with Parallel Flow heat exchangers & BAM coils?
Give me good answers to this questions and maybe I will take some time with you, as long as your intent is not only negativity.
No disrespect intended
Perhaps the next time you start making comments about something someone started to post here, “said it was not finished yet and would be finished later”; you will wait until they FINNISHED what the started writing that was not finished, so you know what it is before you make a comment about something so far off topic it has nothing to do with what the person was writing about!
P.S I never said anything in any of my posts about the anemic Bosch blower fan except I DO NOT USE IT!!!
Now I can go back and finish what I started writing this morning
"...Now I can go back and finish.."
Why bother, By your standards, high-lighted above, your requirements for our understanding most of what you write is beyond our comprehension.
Old 08-04-2011, 03:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #183 (permalink)
RetroAire system condenser
Originally Posted by Cloggie View Post
I think it is an excellent condenser.....looks very similar to the one that I am installing as part of the RetroAire system, in fact, it was the condenser that convinced me to go with Retroaire rather than some of the other set ups.
Mine is very light and small, and I gather if I believe the bumpf about it...they are also efficient.
Here is a pic of my install (as yet untested)
D.
I have one of these same exact condensers and have completely thoroughly tested it on my 911, Then removed it because I was not satisfied with its efficiency or its vey old Parallel Flow condenser technology, after I tried and tested several other newer designed technology condensers , but I will say it works better than anything Porsche and/or Behr has for a 911 which is not saying much, except to say RetroAire’s claims are overblown
THE ONE I BOUGHT DID NOT COME FROM RetroAire ; the condenser is American Made and I bought it strictly for testing purposes, and I was disappointed in it after I tried and tested several others newer ones to say the least before building my own.
This is a “Generic Universal Parallel Flow condenser”, is using rather very old technology called “Multi-Flow technology” compared to today’s much newer Parallel Flow condenser technologies!!!
FYI Parallel Flow “Multi-Flow technology” Condensers is obsolete technology and I DO NOT USE IT!
If you want to save a few dollars you can use it I guess, it definitely works better then what you have but that is not saying much because I have been there and done that and if you want to spend your money on old technologies instead of new technology I leave this up to you
As a courtesy and respect to RetroAire I am not going to rain on their parade and post the link to where this same condenser can be found much cheaper
Reid
Old 08-04-2011, 06:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #184 (permalink)
Reid
...Reid, just a small note of caution. I realize you are passionate about your work and are more than likely correct about the efficiency, but you just want to be careful not to diss people who are otherwise happy. Leave it as being that you are working on a better mouse trap and take care not to cast too many aspersions on other companies or people who knowingly bought from them.
I do hope you are able to get your product well into market and it gets picked up by some of the vendors that you refer to, or perhaps you become a worthy competitor for them.
D.
Old 08-04-2011, 07:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #185 (permalink)
wwest's Avatar
Greetings to the moderators and to all the users here! And Thank You to Pelican Parts for hosting the technical discussion area’s for many years!
Happy Fourth of July Holiday; looks like summer is here
Having owned a 911 for 20 years and I having enjoyed reading here for many years, the information I have found reading here is invaluable to say the least to gain technical knowledge and the people seem very friendly and helpful.
I would like to start a new discussion thread related to 1963-1989; 911 930 & 912
Porsche A/C Front & Rear, Parallel Flow micro-channel Condensers and the latest technologies in evaporators, the prior discussion about Parallel Flow micro-channel Condensers people here discussed is very old and I believe I have new things to contribute related to vintage 911 Porches A/C systems.
I had tried to buy Parallel Flow micro-channel Condensers using the latest technology for my front condenser after reading here and several other places on the net and much searching worldwide for them without success for almost 4 years to fit my 1975 911 Carrera to replace my stock Tube & Fin OEM condensers
I Finally GOT angry I could not buy one anywhere to use as a front condenser so I have made several of my own custom designed front and rear Parallel Flow micro-channel Condensers prototypes that use the latest micro channel technology
My interest started out as a project to make my old 911 cold after many years of only having my car cool but not cold driving it daily. I live in Fort Lauderdale in south Florida, the weather here is a year round is a tropical climate with much of the year having high humidity and using air conditioning year round here almost every day is a MUST for everyone here except for a few weeks a year. In summer due to the high humidity especially in August and September the heat is brutal.
I have a friend who has a Porsche repair shop here called Stokes Automotive I am using to make and test what I am making and I will post more pictures soon
"..made several of my own..."
If "you" were in charge of making these than why are they not fully form and fit compatible with your target market....?
Isn't it rather ARROGANT to ask ALL your buyers to modify their cars in order to fit something you "made", something that in the end that will prove to be less effective, efficient, and a LOT more expensive, that simply installing 2 12 volt fans at $34...?
Something you found on the Russian internet...?
Old 08-04-2011, 08:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #186 (permalink)
MAGA
Tim Hancock's Avatar
KelogGes, is your tubing from Brazeway?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-04-2011, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #187 (permalink)
looks like it. Brazeway Automotive micro-multiport tubing Â
206 637 4071
Old 08-04-2011, 10:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #188 (permalink)
MAGA
Originally Posted by john walker's workshop View Post
Just curious... I have designed machines that help them produce the stuff along with other types of aluminum tubing they make.
0% Liberal
Old 08-04-2011, 12:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #189 (permalink)
That's Patent Pending
Old 08-04-2011, 12:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #190 (permalink)
Originally Posted by tim hancock View Post
kelogges, is your tubing from brazeway?
no
Old 08-04-2011, 01:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #191 (permalink)
Carrera 3.0 1975
André 3.0's Avatar
Subscribed, ..........do you ship to Europe?
1975 Carrera
Carrera3.0 1975
Old 08-04-2011, 02:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #192 (permalink)
1975 Carrera
Hello André,
Thank you for asking
Answer unfortunately at least for now I must say NO
I am just starting up what I have invented which is Patent Pending and my patent attorney has advised me not to export outside the USA at this time
For your information;
I have worked on FEADSHIP's on and off for 30 years related to Marine engineering; I have great repect for people in the the Netherlands ( believe you know about FEADSHIP ?)
Old 08-04-2011, 04:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #193 (permalink)
brads911sc's Avatar
I like this idea... but the only way I would buy a new front condensor at hundreds of dollars is if it fit the stock location.
There is no point with the crappy fan that is pushing air through it. The limiting factor between yours and the Rennaire Dessert Duty I have already is not the condensor its the amount of air generated by the Bosch Fan.
I would be game on the rear deck condensor. I already have a fender mounted supplemental condensor with a fan.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 08-04-2011, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #194 (permalink)
brads911sc's Avatar
I disagree. I have a supplemental condensor with a hight output fan... it helps, but the deck lid condensor performance absolutely was NOT mitigated by adding a $34 fan...
" something that in the end that will prove to be less effective, efficient, and a LOT more expensive, that simply installing 2 12 volt fans at $34...?
Old 08-04-2011, 05:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #195 (permalink)
wwest's Avatar
".....but the deck lid condensor (poor) performance absolutly was NOT mitigated by adding a $34 fan....
First, $34 gets you TWO fans.
You imply that you TRIED the deck lid fan(s) technique and it did not work to your satisfaction...
How so...?
Old 08-04-2011, 06:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #196 (permalink)
brads911sc's Avatar
i am not saying that fan(s) dont help. i am saying that if you want 35 degree vent temps in 96 degree 80% humidity texas weather (it was 106 today)... adding 34 dollars worth of fans isnt going to get you there... been there done that... you need a wholistic approach to AC in the 911 anytime its over 88 degrees.. changing the evap to more efficient type, adding high output evap fan, changing condensors to more efficient models, adding supplemental condensors with fans.. will get you there. What this guy is selling is in fact one peice of the puzzle. Griffiths and Rennaire have proven that. I was merely pointing out that saying that an upgraded superior condensor is a waste of money and all you need is 34 dollars worth of fans... is really oversimplifying the problem for anyone in the southern half of the US.. Wouldnt you agree?
Perhaps in the Paciffic NW that is all you need... I assure you that you would be VERY unhappy in Houston TX if that is all you did...
Old 08-04-2011, 07:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #197 (permalink)
wwest's Avatar
"..I assure you..."
I hope you don't mind if I don't take your word for that.
IMMHO the proof is in the pudding.
To late to plan for this year but maybe next year, August, we can bring our '88 to "planet" Houston. You do know, do you not, that the Porsche 911 A/C sysetm is ALWAYS in recirculate. If you can deliver a continous flow of liquid refrigerant to the evaporator expansion valve, you're home free.
Oh, looking down into the "cubby" today I couldn't help but think discharging a full can of "Good Stuff" to fill in, isulate, the exterior of the evaporator/blower plenum might be of help.
Old 08-04-2011, 08:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #198 (permalink)
M Logo
No disrepect, you made some comments,
My reply is not ment just for you, many people are reading here that do not post post messages in the channel, and there are somethings going on in the background
As such this is my reply
Please note: I will do a long post about condenser blowers/fans soon when i have more time
FYI or anyone who missed this; My patent pending front condenser was specifically designed to fit within the 911 930 stock location!!!
I guess some people don’t bother to read everything I have taken the time to already address and written here, then make comments
I GUESS YOU NEVER READ WHAT I SAID/WROTE HERE A MONTH AGO WHEN SOMEONE SAID BASICALLY THE SAME THING YOU SAID TO ME TODAY? THAT I ANSWERED ALREADY ABOUT A MONTH AGO
However my front condenser ON PURPOSE does not use the original OEM screw holes because MY SPECIFIALLY INTENDED DESIGN IS slightly larger in length and width, but it also mounts far more securely to the front pan underside body then the OEM condenser does. THERFORE if a rock guard is going to be used, the rock guard will need to be modified or be replaced with a new fabrication
When I read some of the posts here by others; You guys just don’t seem to get it sometimes, SOME OF YOU ARE LOCKED INSIDE A BOX OF OLD TECHNOLOGY and attitudes that never worked VERY G-O-O-D ON 911s!
Porsche 911 930 A/C history lesson 101 GENERAL KNOLEDGE
Never forget THIS SIMPLE FACT; Porsche never designed the 1963 to 1989 911/912 930 body to accommodate air conditioning to be used PERIOD!!!
A/C WAS AN AFTER THOUGHT ONLY, caused from Porsche 930 USA American sales demand!!!
AFTER the body HAD BEEN SET IN STONE, and Porsche never changed it, until about the END of 1989; The 930 body was completely redesign for a completely new model, and that for the very first time EVER; the replacement model FINALLY had an air-conditioning system included IN THE NEW MODEL BODY COMPLETELY RE=DESIGNED AS AN INTEGRAL PART OF THE NEW BODY!!!
I am not like most people!
I think outside the box, I have new technology never before used on a 911 and I have used every possible millimeter available that can be found in the body, if I needed too, to enhance its design to the extreme that I can and still allow it to fit if it enhances it, that Porsche engineers overlooked when they gave BEHR original parameters for design their OEM models Condensers, and furthermore I have done things they either never dreamed of or decided to use for whatever reason, and they both made a lot of mistakes what they dumped on their multitude of buyers to give the world a Porsche car with a bad joke for an a/c system.
You would have thought that Porsche with some of the best engineers in the world would have re-engineered the 911 somehow in the early 70s to have a decent A/C but I guess corporate greed just did not care enough to fix it!
Well I HAVE DECIDED TO PERSONALLY DO SOMETHING ABOUT IT TO FIX IT FINALLY THEN JUST TALK;
IN MY OPIONION WITH WHAT I HAVE DONE WITH MY LITTLE CONTRIBUTION FOR THIS FINE CAR;
IT NOW WORKS!
I AM USING R-134A and After I DESIGNED, CUSTOM MADE AND INSTALLED 2 HIGH TECH STATE OF THE ART CONDENSERS’ borrowed a RennAire Serpentine Evaporator from Cab after he read about what I am doing here and messaged me to inquire about my condensers;
MY VENT TEMPS HIT MY TARGET of 41; sometimes I get in the mid 30s F, and I know without a doubt when I make further tweaking of the car and the A/C SYSTEM it will only get far colder’ ( except I have been just too dam busy so far making more condensers to tweak it,)
To the Nay Sayers if there are any my question is;
SO HOW COLD IS YOUR 911 AND WHAT ARE YOUR VENT TEMPS NOW IT’S AUGUST WITH RECORD HIGH TEMP???
Old 08-04-2011, 10:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #199 (permalink)
wwest's Avatar
Cool
IT NOW WORKS!
""I am not like most people..."
GRANTED..., in spades.
"...I think outside the BOX.."
And therein lies the problem...
A little more thinking inside the box (rock guard box), common sense, non-degreed shade-tree mechanic thinking, would be of tremendous aid.
"...WHAT ARE YOUR VENT TEMPS..."?
And the price of tea in china is....
As long as the compressor system can deliver a continous stream of liquid refrigerant to the evaporator expansion valve NOTHING else matters on the HIGH side.
Your upgrade is not only useless in that scenerio and therefore extraordinarily costly.
You have a good idea, but why not stop with the rear condensor, properly sized, and fit 2 inexpensive fans....?
TRY IT, you might LIKE IT.
Since you're running trials anyway.
Why do you talk about air-to-air condensors on shipboat when there are so MANY BTUs to be much more easily had in that water...?
Old 08-05-2011, 07:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #200 (permalink)
Closed Thread
