SC Flapping Mirror
My passenger side Mirror is flapping around (the whole assembly), does anyone know how many bolts should be holding it on to the door? Thanks
1988 Carrera
996
The allen head screw between the window and mirror is the only bolt holding the mirror on. |
1988 Carrera
IF the base is not loose then you will have to take the mirror apart and remove the wiring and tighten the hollow bolt.
83 911 Production Cab #10
Should be only one. Hex type if I remember well.
It does not screw into something but rather tight a J hook to the body. The bolt and J hook are in line with the cap (red arrow)
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Had my mechanic do mine... it's kind of a 2 man job.
Member 911 Anonymous
If at the pivot, then the Hollow nut or the 4 bolts behind the glass.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
To expand this discussion, is there a bolt to also tighten the pivot point for the chrome side mirrors (or the reproduction side mirrors)? My drivers side mirror flops when I'm driving at highway speed.
1975 Widebody 911 3.2 Euro |
Thanks guys, much appreciated
Roger That!
