Here is a before and after that Oh Haha was talking about. Before: stock muffler and cat. After hollowed cat and Bursch muffler.
YouTube - ‪Stock muffler with cat. converter‬‏
YouTube - ‪New Bursch muffler plus ride height‬‏
Mike
Old 07-06-2011, 08:57 AM
One more:
YouTube - ‪1986 Porsche 911 Carrera with Bursch Muffler‬‏
Mike
Old 07-06-2011, 09:00 AM
kdog_us's Avatar
Originally Posted by kinein View Post
i am selling it 75 for it i also have a vertex chip also you can have them both for $100, i am supercharging my car so i dont need......
Thank you. I will think it over. Havnt decided what path to go down yet.
Old 07-06-2011, 10:29 AM
kinein's Avatar
Send a message via Yahoo to kinein
yeah no problem its still on the car sitting in the shop being put together soooooo
Old 07-07-2011, 07:26 PM
Mad scientist
Peter Bull's Avatar
Originally Posted by kdog_us View Post
Anyone ever do their own cat bypass utilizing most of the existing plumbing? 86 3.2L
As a little experiment to learn to weld with a TIG I made my own test tube form a small pile of stainless tubes and a couple of stainless plates.
A little bit of machining, welding, beating and swearing later, this was the result:
Please excuse the ugly weld beads, but it was my first attempt at welding stainless steel. Anyways, this was how it looked mounted on the car:
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 07-09-2011, 01:44 AM
kdog_us's Avatar
That looks great Peter. I hadnt thought about making my own mounting plates. Good idea. Did you weld in a bung for the O2 sensor?
Old 07-13-2011, 03:52 AM
Mad scientist
Peter Bull's Avatar
Thanks,
the car didn't have a cat or an O2 sensor. But it shouldn't be too difficult to fit a bung for the sensor if needed.
/Peter
'84 911 Carrera
'91 928 S4
Old 07-13-2011, 08:00 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Holy Shiznet! That is Ugly Awesome! How does she sound and feel?
Any change on low end torque and high end torque?
Honestly, not bad for DIY. I am practing on my new welder from HB as well. Any hints or tips?
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 09:02 AM
Somewhere in the Midwest
MotoSook's Avatar
If its just a matter of coring the cat, why do so many people by the m&k bypass?
Because it's sparkly! LOL!
Really, a gutted cat works just fine. Don't let the internet-dyno cost you money.
I even cut and welded up a Cherry Bomb glass pack for my old 3.0 for less than $30...worked great sounded great without pissing off the neighbors and sounding like a teenager in a Honda with a fart can.
Old 07-13-2011, 09:05 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
Wear a dust mask.
And miss out on the free buzz? Grind that stuff up and snort it!
SOLD: '87 Carrera
Old 07-13-2011, 09:09 AM
If your going to purchase a bypass pipe, you can sell your existing cat on the forums, or sell to a scrape yard for 50 dollars. Someone mentioned already, there are precious metals that make up the "honeycomb". This is the reason why so many SUV's lately are having their factory cats stolen.
84 911 - 88 944 Turbo S - Sold
996 Turbo
996 Cab
Old 07-13-2011, 09:10 AM
I took a standard gutted cat. Got a piece of exh pipe the same diameter as the inside bore of the cat. Drilled many holes in its entire length to identically mimic what the inside of a sport cat or glass pac lining might look like. Then weldeded that section of drilled pipe inside of the gutted cat. Sounded better and throttle response felt better better. How much, dunno didnt test it, didnt care to, just wanted to free up the exhaust a bit. Looked just like it was all still there. It appeared to me that due to the reduced back pressure my older engine was using more oil than it was prior, hence I took it off and put the cat back on.
Sorry cant provide pictures as thieves recently stole the home pc's and camera's.
If interested I might consider selling.
Mike
Valley Grande, AL
1987 911 Targa, White
Old 07-13-2011, 10:30 AM
kdog_us's Avatar
how much are looking to get for it?
Old 07-13-2011, 05:36 PM
Mad scientist
Peter Bull's Avatar
Gee, thanks Even though it looks bad its withstood about 10 years and 100,000 km of abuse.
To be honest, I can't say i noticed much of a difference when i mounted the bypass. No difference in power or torque. Since the car had a cracked pre-silencer and no cat there shouldn't be much difference. It sounds a little bit more, but not much, and there is a slight ting to the sound which I've been told comes from using stainless steel.
I could give you a couple of good reading tips on welding, but I am afraid the books are in Swedish...
/Peter
'84 911 Carrera
'91 928 S4
Old 07-14-2011, 12:37 AM
DRACO A5OG's Avatar
Ja, I know very little Swedish. One of my clients is swedish and she taught me some but not enough for a Swedish tech manual :-P
Still, very good work
/Peter
'85 Carrera Targa
PCA/POC
Old 07-14-2011, 08:50 AM
kdog_us's Avatar
**Update**
Decided to build my own cat bypass. Here is how it went...
-2 into 1 pipe from the heat exchangers - freebie from the local Porsche mechanic.
-3 hole flange, 2.5 in dia exhaust pipe, flared on one end, and O2 sensor bung - $25
-mounting hardware - $5
-local muffler shop to torch off old hardware - $20
Total cost - $50
Welded together the pipes and new flange, drilled hole and welded in new O2 sensor bung. Final assembly was a piece of cake. Sorry no pics.
Results
Slightly improved exhaust note. Its a little deeper
No noticable power improvement.
All and all, it was a days work, fun and simple.
Old 07-18-2011, 05:05 PM
Oh Haha's Avatar
**Update**
Total cost - $50
Results
Cool!! It's always gratifying when you DIY a project.
What muffler did you use?
Pacific Blue
Wayne
Old 07-18-2011, 05:23 PM
kdog_us's Avatar
Stock muffler for now. My budget requires baby steps
Old 07-18-2011, 05:41 PM
DRACO A5OG's Avatar
Try it at speed on the highway or freeway, you will love it when you down shift to 4th
'85 Carrera Targa
PCA/POC
Old 07-18-2011, 06:17 PM
Tags
cat bypass , diy
