Ethopian Assistant?
I have a new-to-me '85 euro 911 with ac. Yesterday I did my first bit of maintenance, changing the oil and air filter. No problems, but - here's my question - is there a trick to getting the forward-most bottom latch secured? I ended up unbolting an ac line and squeezing my arm past all of the crap to get to the latch, and I still have some pretty impressive bruises. What am I doing wrong?
Old 07-10-2011, 06:53 AM
JerP's Avatar
I have since removed my ac, however, if I remember you get to it from over the top right. It is a tight area to work in.
Jeremy
85 Targa
Old 07-10-2011, 07:06 AM
Drisump's Avatar
What are you doing wrong?.....Nothing, on my 85 Euro it is almost impossible, Cheers
Old 07-10-2011, 07:31 AM
Canucks Fan
My wife has skinny arms so she helps me with that sorta thing but don't get married for that reason, in the long run its cheaper to rent than it is to own. any skinny armed kids in the area?
From the Deep Dark Jungle
Old 07-10-2011, 09:02 AM
Member 911 Anonymous
DRACO A5OG's Avatar
How about a anorexic teenager? :-P
I modified my OEM Air Box Cover. Got rid of the Trombone and it is easy breezy to get to the latches.
The only other thing I can think of is to lower the engine couple of inches, but what big PITA
'85 Carrera Targa
PCA/POC
Old 07-10-2011, 09:42 AM
I can get it latched with my left hand without removing anything. I stand on the right side of the car and stick my left hand in beside the air box with my thumb pointed down. I can just reach the latch with my fingers. It's painful but it works.
John
'86 911 Coupe
Old 07-11-2011, 09:57 AM
I put a tie wrap around the pull part of the latch. easier to grip it.
Ned Nyna 11
87 Carrera Targa
98 528i BMW
2004 Jetta 1.8T
Old 07-11-2011, 11:05 AM
My wife wasn't having any of it, and my 12 year old son, who thinks the car is his, couldn't quite grasp (sorry) the method of latching. Next time (10,000 miles or so?) I replace it I'll try the beside the car left hand idea. Thanks...
Old 07-11-2011, 11:09 AM
Drisump's Avatar
I was thinking of trying that method the next time....it works?
Old 07-11-2011, 11:23 AM
I am no Popeye but I have to get my arm wet with very soapy water. Once my arm is lubed up I can perform the operation. Just shove it in hard and snap the latch. I always figure it is how a protologist must feel doing his job.
Then I just use a damp cloth to wipe the soapy water off the engine parts.
Old 07-11-2011, 11:32 AM
