brads911sc's Avatar
3.2 SS Spark plug
I have a newly built 3.2 SS, Compression 9:5.1, single plug, large port heads, ITBs, MSD, gapped at 40.
I am running the Bosch WR5DC+ Spark Plug that is stock on the 3.0 (80-83).
The 84-89, 3.2 runs WR7DC+
What should I be using? switch out the 5's for 7's since its not a stock 3.0?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-13-2011, 08:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
7's on 3.2
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 08:17 PM
Chief Head Scratcher
kerthunk's Avatar
I have a fresh 3.2SS as well, but using CIS. I was going to run the WR8DC+ since I had a '79, but Steve Weiner told me that they would be much too hot and he recommended that I go with the WR5DC+ instead.
John Morris
'79 911SC
Old 07-13-2011, 08:37 PM
kinein's Avatar
Send a message via Yahoo to kinein
which one is the turbo plug for the 930 heard it runs cooler i am running a supercharger setup i have read that should switch up too turbo plugs so which one are turbo plugs?
Old 07-13-2011, 08:51 PM
FPB111's Avatar
Bosch higher number is hotter
NGK higher is colder
I would run the coldest plug that does not foul, hot plugs can hurt.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 07-13-2011, 09:33 PM
kinein's Avatar
enough said about that one........
Old 07-13-2011, 09:39 PM
kinein's Avatar
so what ngk would you run?
Old 07-13-2011, 09:44 PM
kerthunk's Avatar
Have you tried pulling the plugs to check for fouling?
John Morris
'79 911SC
Old 07-13-2011, 10:02 PM
kinein's Avatar
i just bought this motor with 62k on it, ill be putting my supercharger on shortly in a couple of weeks....so i am tryin to get some fuel injectors replaced and cooler plugs to run
Old 07-13-2011, 10:11 PM
T77911S's Avatar
+1
always run the coldest plug you can.
the main reason for hotter plugs is the idle circuit, it is richer and needs the hotter plug to keep clean.
i ran a WR4 in my 2.7 as a test. the plug was black from idle and driving around town, but when i took a trip, 9 hours of leaner burn mid RPM's, the plug was clean and white/tan.
start with a cold plug (wr5), check them every 100 miles and see how they look.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-14-2011, 05:07 AM
db_cooper's Avatar
I did not know Porsche made a two stroke engine...love the two compression rings and no oil control ring..
Old 07-14-2011, 10:17 AM
brads911sc's Avatar
Thanks All for the feedback. I have had no issues with my 5's. I just had realized that many with a 3.2 mention 7's so i didnt want to cause any harm by running a cooler plug. Ill keep the 5's unless I see an issue...
Old 07-14-2011, 11:29 AM
Keep the 5's.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-14-2011, 11:31 AM
brads911sc's Avatar
Thanks Steve!
Old 07-14-2011, 11:32 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The annoying thing about heat range numbers is not only are they not consistent from brand to brand (like others said lower # is hot, higher # is cold in NGK speak, and vice versa in Bosch speak) but also the numbers don't directly correlate. For instance the NGK BP5ES or BP6ES is good for carbs. Well that sounds like a far cry from the Bosch 5, but it's not.
Kevin L
'86 Carrera "Larry"
Old 07-14-2011, 01:46 PM
Halm's Avatar
What gap would be recommended for the WR5DC+?
Thanks.
'17 Cayenne
Old 07-30-2011, 03:57 PM
Thanks.
What kind of ignition wires are you running?
Old 07-31-2011, 09:37 PM
Halm's Avatar
As far as I know, the wires are stock, or OEM style, as is the rest of the ignition system.
'17 Cayenne
Old 08-01-2011, 04:21 AM
Stock wires=stock gap. ~0.028"-0.030"
Old 08-01-2011, 05:57 AM
Halm's Avatar
Thanks!
'17 Cayenne
Old 08-01-2011, 08:08 AM
