help with fire order problem
hi guys... after changing the plugs and wires I am having rough idle issues. I am curious why factory steel braided wires are grounded and the magnacor ones are not?
anyway after reading other posts I found out by using a timing light and hooking it up to each wire I could find out which one is not working. I discovered that #4 is not working but all others were. I thought if I messed up wire connectors to dist then two would not work. I put old plugs and wires back on and same results. I know from bentley manual the notch on on dist where number 1 is but I have double checked all wires are in the right places. what am I doing wrong????
81 SC coupe |
the bentley manual may have an error - the SC distributor turns counterclockwise. check the direction with other sources. also I think the rotor pointing to the notch is only showing TDC if the TDC mark on the pulley lines up with the mark on the case; otherwise it may be 180 degrees off.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) Last edited by schumicat; 07-18-2011 at 12:34 PM.. |
cycling has-been
from one of our multi-talented members....
thank you Darrell ....(please check in once in a while)
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 07-18-2011 at 05:05 PM.. |
It won't even start.........
If the distributor is 180° off, it won't even start or idle. The fact the the poster has the engine running (rough), it negates the 180° off assumption. Tony |
thank you thank you! benltey has made an error counter-clock wise did the trick.
she fired right up. thanks again.
81 SC coupe |
Holy sheeit.......this was what ICE was talking about , long ago!! Those years,...
WOW, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
RETIRED
Bentley MAY have an error? THEY DO have an error.
The SC dizzy turns the opposite way of other Porsche flat 6s and they don't even admit the error on thier website or fix it in later editions.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Member 911 Anonymous
+1 Bentley is very inconsistent, at least Haynes will help you if you call them.
I called them and they were very upity
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
