HELP... Glove Box Won't Open
73 911.....and glove box is stuck... was working..tightened up the lock now stuck.
any suggestions?
TIA
Old 07-20-2011, 07:01 AM
moneymanager's Avatar
Undo the bolt holding it in underneath, remove box. then open from inside.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-20-2011, 12:44 PM
RETIRED
Joe Bob's Avatar
Slide a thin piece of metal like a flexy ruler or a credit card into the gap and slip the lock.....
2012 ML350 3.0 Turbo Diesel
Old 07-20-2011, 12:47 PM
Taking it apart is easy
Jerome74911S's Avatar
I had the same problem with my '74. I could not remove the bolt holding the box in place by working from underneath. The bolt will not back out far enough to release the bracket.
What I had done is install the lock with its latch on the wrong side - it should have been flipped 180 degrees. You might have done the same thing when you reinstalled the lock.
In the end I cut the strap that holds the glovebox in place. The box comes right out, you can reach the lock, remove it, and turn it right for left where it will work.
Sadly, you will then have to repair the strap. I just pop riveted a small piece of strap material to the strap. Works fine.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-20-2011, 01:47 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeah, you may have over torqued the nut too, causing it to bind. Remove the rubber cover on the knob and put a vise grip and turn it. be gentle though.
Undoing the knee pad or credit card thing is also a good idea.
Remember our cars do not need much torque on fasteners. Snug & 1/4 turn or always default to PAG spec.
'85 Carrera Targa
PCA/POC
Old 07-20-2011, 02:06 PM
