Does anyone make closed steel lug nuts for the 911?
My car has the factory aluminum lug nuts and, somehow, they don't inspire me. Using my air wrench, even to get them off, makes me a bit nervous.
Our kind host here carries open steel lug nuts, which would probably be fine given the use this car gets, but I'd rather have close ones. Does anyone carry them? Thanks.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
sudo apt-get purge 930
You should NEVER use an air wrench on ANY lugs nuts. Torque wrench only!!!!!
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Max Sluiter
The steel ones are for racers since many sanctioning bodies want steel lug nuts. They are open so that one can easily see the amount of thread engagement.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Further, my air wrench at lowest setting puts steel lug nuts on to ~60lbs and I use a torque wrench for final torquing. There's nothing wrong with that.
But does anyone make closed ones for street use, like most normal cars have?
Max Sluiter
I've seen open Aluminum but not closed steel made for a 911 with the ball seat.
Thanks. I guess I'll just live with the current ones and be careful.
I agree with that. I thought you used it for install on aluminum too.
Now, with the 911 it's a different story. The aluminum lug nuts are light enough that the 2135 would torque them higher (due to spinning them faster) than I'd want initially even at the lowest setting. It'd probably get to 80 ft/lbs or so. I suppose I could investigate a torque stick or maybe use my 3/8" air wrench. I do know how to use the things though and I won't over torque the nuts.
They remain one of the really cool parts of Porsche engineering. No, in general Porsche lug nuts are closed for aluminum and open end for steel. There are a few exceptions not worth mentioning here. Quote:
Yes, I use an impact wrench on my steel nuts – both directions but only as a ‘speeder’ when tightening. Yes, always use a calibrated torque wrench to finally tighten to 96 ft-lbs (steel or aluminum). Re-check afterwards. There are some good threads about lubrication for the threads and ball seating surface. Aluminum nuts need a full-length 6-point wrench and benefit from ‘soft’ plastic inserts. Some years ago, I posted a cool VW part that covers a standard steel lug nut – original 914 application. I use these plastic covers on my 911 (6&7Rx15 Fuchs with steel nuts and long studs). There are also good discussions about the differences in lug nuts – steel and aluminum. Search is your friend. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
912 Geek
Don't forget, too, that there is (or used to be) a special "soft" socket for the aluminum nuts that protects them from damage. S*t*o*d*d*a*r*d sold them, but perhaps Pelican offers them, too.
Frank |
Yes, someone has them as I have a set that look exactly like the aluminum closed lug nuts, but they are made from steel. So, what you are looking for is out there, I just have no idea where to send you to find them. All the best, Craig
A most excellent tool from our host
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Banned
a.k.a. G-man
The soft socket I have is not suited for use with an impact wrench either. It's lined with a very durable type of plastic on the inside and outside so you won't damage the nuts nor the wheels.
![]() 'Bout the lugnuts, AFAIK, closed ones are Alu and open ones were steel.
Сидеть, ложь, Переворачиваться |
Almost Banned Once
Search "lug bolt covers" on EBay.
- Peter |
To complete the offer, there exists a lugnut from the 944 Turbo Cup series (the race cars, not the silver rose) that is steel, long as the alloy lug nut, but open at the end.
I'd pay good money for such a set. |
Contact Harvey Weidman, of Weidman's wheels, he has a service where you send him your extra set of lugs, the end is cut off and refinished. As I recall the quote was $5 per lug.
I am not sure you read my post. Or understood it.
