all the fish in the Puget Sound will love that run off from the cleaning.
Like a proud Daddy !
http://forums.pelicanparts.com/uploa...1317086541.jpg You do nice work Thor !! What direction carb wise are you going to go with ? I'd like to do that eventually (PMO ??) with the SC, but it's going to take a lot of money & time to get it track ready first ! I like your exhaust too! Friday, spent the day at my friend's putting the new oil cooler on the 2.2 '70E engine (small leak found on the old one after the engine rebuild.). Hopefully ready this week --> Mid-Ohio next week !!! Nuthin' like a clean engine ! http://forums.pelicanparts.com/uploa...1317087986.jpg |
Way to go Thor! It looks great! Are you adding cams or was this just meant to be a repair and clean job? Either way, it looks great and you have been truly indoctrinated:)
Hey Brian ! What have you been up to ?? I see a PCA treasurer now.....
I've been the Treasurer now for 7 years brother, lookin' forward to hanging up that hat next year sometime if they'll let me:)
I've been well, just chasing the family around as the kids grow older and get more active in sports. Very little track time for me, unfortunately. I don't think I knew you had an SC as well, but it's been a long time... |
Nice collection of plastic on the shelf in the background!
Working on my 77, 911 has cut into my modelling time too.
Cheers James in Oz Quote:
Good eye James! I've found a new hobby for now. Thanks Rich and Brian. No carb$ and no cam$ for now. Just want to get it back together and learn to drive it. Thor |
Krylon overhaul of the oil tank....Stripped , primed and painted. Engine tin back from powdercoating. Cylinders installed. Cam timing coming up soon.
http://forums.pelicanparts.com/uploa...1318776055.jpghttp://forums.pelicanparts.com/uploa...1318775453.jpg http://forums.pelicanparts.com/uploa...1318775488.jpg http://forums.pelicanparts.com/uploa...1318775525.jpg http://forums.pelicanparts.com/uploa...1318775559.jpg http://forums.pelicanparts.com/uploa...1318775593.jpg |
Thor,
Nice work. Taking all that time to get it clean, really pays off while you're working on it......and when you are done...it's a thing of beauty. regards, al |
Progress report
Progress has been slow with life going on but with stormy weather outside I was able to spend the last couple days in the garage. Got the cams timed and valves set today. Picked up the rebuilt starter and alternator and the tins from the powder coater. No rush now that winter is setting in but things should progress rapidly now.
Thor http://forums.pelicanparts.com/uploa...1321492654.jpg http://forums.pelicanparts.com/uploa...1321492706.jpg |
Getting closer to being back together. CIS restore up next...
Thor http://forums.pelicanparts.com/uploa...1321862430.jpg http://forums.pelicanparts.com/uploa...1321862458.jpg |
Looking good Thor.......................this week is supposed to rain right through the weekend.....should get a lot done.
regards, al |
Great job Thor. Looking mighty fine.
Rob G |
That's a nice piece of work --- of art! Congrats on the outcome. It's clear that you spent lots of time and hard work on it.
I see that you mount the engine directly to the engine stand. Is that the Harbor Freight stand? Or Ebay? BTW --- "Brown747" --- I would guess that you fly UPS 747 cargo planes? [QUOTE=Brown747;6383459]Getting closer to being back together. CIS restore up next... Thor http://forums.pelicanparts.com/uploa...1321862430.jpg |
http://forums.pelicanparts.com/uploa...1322714184.jpg
"That's a nice piece of work --- of art! Congrats on the outcome. It's clear that you spent lots of time and hard work on it. I see that you mount the engine directly to the engine stand. Is that the Harbor Freight stand? Or Ebay?" Harbor Freight stand and the top engine studs fit directly into the stand mounting plate. Because of the protruding lower studs it will not rotate beyond about 30 degrees either way from horizontal. As it is just supported only by the top 2 studs I would not want to turn it much beyond 30 deg. I will mount the exhaust then lower it to my ATV jack to finish up mounting the flywheel and clutch as there is not room with this stand setup. Next time I will spring for the correct mounting flange. I would also like the stability of a stand that has 2 "feet" as this single in the middle T design is getting less stable as the weight from accessories adds up. BTW --- "Brown747" --- I would guess that you fly UPS 747 cargo planes?" Yes, I fly the Whale for UPS. Thor |
Thor,
I have the adapter for the engine stand. You are welcome to borrow it and my stand, if you'd like, for the duration of your rebuild. regards, Al http://forums.pelicanparts.com/uploa...1322720466.jpg http://forums.pelicanparts.com/uploa...1322720484.jpg |
Thanks for your offer Al! I'll give you a shout next week sometime....Thor
Back together!
Just wrapping up my lower stud change and cleanup project. Deleted A/C, cruise control, smog pump and associated plumbing, backdated heat, installed later style cam chain idlers, powdercoated tins, added SSI's and Monty. Next up , replace clutch cable and tunnel fuel lines before re installing. On track for a spring return to the road. Thanks to all that offered help and advice during this project.
Thor http://forums.pelicanparts.com/uploa...1324236502.jpg Before http://forums.pelicanparts.com/uploa...1324236615.jpg After http://forums.pelicanparts.com/uploa...1324236562.jpg |
Whoa, she cleaned up nice :D, my compliments!
Sweet job indeed!
| All times are GMT -8. The time now is 05:56 PM. |
